jamesm113 Posted January 13, 2011 Report Share Posted January 13, 2011 Do most hot tub heaters require the pump to be running to work? Or will the heater operate correctly without a pump running? Thanks, James Quote Link to comment Share on other sites More sharing options...
PoolSpaGuy30 Posted January 13, 2011 Report Share Posted January 13, 2011 Do most hot tub heaters require the pump to be running to work? Or will the heater operate correctly without a pump running? Thanks, James yes they do, whether it is a circ. pump or a jet pump "flow" is required for the heater to operate. Quote Link to comment Share on other sites More sharing options...
Roger Posted January 14, 2011 Report Share Posted January 14, 2011 Do most hot tub heaters require the pump to be running to work? Or will the heater operate correctly without a pump running? Thanks, James Otherwise it will boil the water out of the heater tube and burn up the heater. Quote Link to comment Share on other sites More sharing options...
jamesm113 Posted January 14, 2011 Author Report Share Posted January 14, 2011 Okay that's what I thought, but I wasn't sure if they made some heaters with some sort of embedded pump or something. Thanks! Quote Link to comment Share on other sites More sharing options...
Roger Posted January 15, 2011 Report Share Posted January 15, 2011 Okay that's what I thought, but I wasn't sure if they made some heaters with some sort of embedded pump or something. Thanks! The 2 work together. The pump will run without a heater but the heater needs flow through it in oder to heat up. It does this by way of a sensor to detect flow. Once flow is detected the heater will light up whether it's electric or gas. Quote Link to comment Share on other sites More sharing options...
jamesm113 Posted January 15, 2011 Author Report Share Posted January 15, 2011 Okay that's what I thought, but I wasn't sure if they made some heaters with some sort of embedded pump or something. Thanks! The 2 work together. The pump will run without a heater but the heater needs flow through it in oder to heat up. It does this by way of a sensor to detect flow. Once flow is detected the heater will light up whether it's electric or gas. Ah, okay. Makes sense. Where would that sensor be located? Is it part of the heater itself or does the control panel handle it? Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted January 15, 2011 Report Share Posted January 15, 2011 depends what kind of tub/control system you have, what is your tub & the AGE? Quote Link to comment Share on other sites More sharing options...
Roger Posted January 15, 2011 Report Share Posted January 15, 2011 Okay that's what I thought, but I wasn't sure if they made some heaters with some sort of embedded pump or something. Thanks! The 2 work together. The pump will run without a heater but the heater needs flow through it in oder to heat up. It does this by way of a sensor to detect flow. Once flow is detected the heater will light up whether it's electric or gas. Ah, okay. Makes sense. Where would that sensor be located? Is it part of the heater itself or does the control panel handle it? I't likely after the pump and after the heater itself. But could be between the two. Quote Link to comment Share on other sites More sharing options...
jamesm113 Posted January 15, 2011 Author Report Share Posted January 15, 2011 depends what kind of tub/control system you have, what is your tub & the AGE? not sure about the age, we got it on craigslist. It's a white springs spa. EDIT: it's circa 1995 Quote Link to comment Share on other sites More sharing options...
