tobz Posted November 6, 2010 Report Share Posted November 6, 2010 Looking for a little advice on a leak in a 2005 Sundance Altimar. Noticed it recently and tore the panel of to discover the source of the water seems to be the impeller housing on pump #1. Access is pretty good and looks like the pvc lines are connected with hand tightened compression fittings. The $64 question - is this a DIY job? If the seal is what has gone bad here, how difficult is this to repair once i track down the right part? Thanks in advance for any help in this. Quote Link to comment Share on other sites More sharing options...
wuice Posted November 7, 2010 Report Share Posted November 7, 2010 If the impeller comes off easily (sometimes they do, sometimes not) it's totally a dyi, otherwise it can be a little tricky. The seal is most likely a 201 Quote Link to comment Share on other sites More sharing options...
