Julianjym Posted October 31, 2010 Report Share Posted October 31, 2010 I have a Tiger River Bengal Spa that seems to have a leak....it's resting on a solid/porous patio so I can't look under or roughly tell where a leak might be without tipping it up...I was wondering before I drain the Spa, what is the construction inside the spa???? Will I be able to see the pipes or are they encased in foam???? What is the most likely spot for a leak???? I checked the component enclosure but no leaks there... Any help would be appreciated...Jim Quote Link to comment Share on other sites More sharing options...
spatech (the unreal one) Posted October 31, 2010 Report Share Posted October 31, 2010 I have a Tiger River Bengal Spa that seems to have a leak....it's resting on a solid/porous patio so I can't look under or roughly tell where a leak might be without tipping it up...I was wondering before I drain the Spa, what is the construction inside the spa???? Will I be able to see the pipes or are they encased in foam???? What is the most likely spot for a leak???? I checked the component enclosure but no leaks there... Any help would be appreciated...Jim It is fully foamed. Since there seems to be no equipment leak you could always let it go until it stops leaking and then by looking at the remaining water level you'll know at what height the issue is. Make sense? Quote Link to comment Share on other sites More sharing options...
Julianjym Posted November 1, 2010 Author Report Share Posted November 1, 2010 I have a Tiger River Bengal Spa that seems to have a leak....it's resting on a solid/porous patio so I can't look under or roughly tell where a leak might be without tipping it up...I was wondering before I drain the Spa, what is the construction inside the spa???? Will I be able to see the pipes or are they encased in foam???? What is the most likely spot for a leak???? I checked the component enclosure but no leaks there... Any help would be appreciated...Jim It is fully foamed. Since there seems to be no equipment leak you could always let it go until it stops leaking and then by looking at the remaining water level you'll know at what height the issue is. Make sense? Quote Link to comment Share on other sites More sharing options...
Julianjym Posted November 1, 2010 Author Report Share Posted November 1, 2010 Thanks for the reply...the water level is going down about 1/8" a day...did you say these leaks will stop on their own??? Are there any weak links on these spas that would be the first place to look??? The spa hasn't been moved since I bought it in 2001...thanks again...Jim Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted November 1, 2010 Report Share Posted November 1, 2010 Feel around under the right front corner (if you are looking at the control panel). If it has the original air-intake valve it could leak in that area. If so, the part is located in the motor compartment even though it will leak outside the compartment. It is located in the upper right corner of the motor comp, would be black or white, and has (2) 3/4" lines and (1) 1/4" line coming off of it. If it's not that make sure you check the light lens closely, also feel around under the corner where the bank of 10 "precision" jets are located. Run those jets for a while and check for water down there. Quote Link to comment Share on other sites More sharing options...
Julianjym Posted November 1, 2010 Author Report Share Posted November 1, 2010 I'll check around...is the air-intake valve under the paddle that determines which jets are on??? thanks... Quote Link to comment Share on other sites More sharing options...
