mag357 Posted September 21, 2010 Report Share Posted September 21, 2010 I have a leak at the union where the water comes from the pump into the filter (Jandy system). It is black ring that looks like it should be tighten by hand but I can not turn it. Is there a tool that can be used to tighten this thing? Thanks Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted September 21, 2010 Report Share Posted September 21, 2010 First, turn off the pump before you do any work to the filter. I use large channel locks to break stubborn unions loose and HAND tighten to assemble. If it still leaks when hand tight, then there is a problem with the sealing oring, or the plumbing isn't lining up correctly. Quote Link to comment Share on other sites More sharing options...
mag357 Posted September 22, 2010 Author Report Share Posted September 22, 2010 Thanks Pool Clown for the reply. It was fine for a whole year and then all of a sudden it starts to drip. Like you say the seal might be going. I will try the channel lock open it a see if I can change the seal. Thanks again for the help. Quote Link to comment Share on other sites More sharing options...
AFiremanFirst Posted September 23, 2010 Report Share Posted September 23, 2010 Channel lock pliers are great, and big ones like we carry are expensive... Grab a cheap pair of adjustable oil filter pliers at the automotive store, they will resemble channel locks with a bigger jaw, and they are curved and give you a better grip. I saw this once when my head was in a dark place on the back side of my body. I was moving valves around inadvertently shut all water off to the pump while it was running. Oops. Take the union off and good luck finding the o-ring, not meaning to sound angry, but I liked to never found just the o-ring, and the union is sold with the heater, so it's a hard item to get your hands on! South Central Pool supply did have it (a wholesaler all over the US) Quote Link to comment Share on other sites More sharing options...
