Houston Dad Posted June 22, 2010 Report Share Posted June 22, 2010 A reputable leak detection company in Houston identified a leak coming off of one of my blowers. Unfortunately the leak is under the pea gravel pool deck. The quote for the repair was over $1k so I'm considering fixing it myself. I'm fairly handy and can easily fix the leak if I can just get to the pvc pipes. Has anyone handled this type of repair and would you do it again if you had to? Any advice would be appreciated. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted June 23, 2010 Report Share Posted June 23, 2010 Did the leak detector pinpoint where the leak is? Thats the hardest part. Quote Link to comment Share on other sites More sharing options...
Houston Dad Posted June 23, 2010 Author Report Share Posted June 23, 2010 Yes, the leak detection company marked the location of the leak by placing red tape in the form of an X on the pool deck. Apparently its where the line coming off of one of my blowers makes a 90 degree turn. I can definitely fix the leak and then repair the pool deck without a problem. I'm not sure what tool I would use to break through the concrete and I'm not sure if the plaster around the blower needs to be chipped out and repaired. Quote Link to comment Share on other sites More sharing options...
IntrustCSLLC Posted June 25, 2010 Report Share Posted June 25, 2010 can you provide pics of the whole area? Quote Link to comment Share on other sites More sharing options...
Groo Posted June 25, 2010 Report Share Posted June 25, 2010 well, I'd probably rent a concrete saw to open up the area over the leak. If you use a jack hammer or sledge, you find a leak there even if there wasn't one in the first place. drain the pool down below the nozzle, then use your pool vacuum to draw up the water to the skimmer to see if its fixed or not before repouring the concrete. you may have to run a garden hose into the skimmer to keep it suction while the water level is low. I used this method to drain my pool for the winter, and it had no problem drawing water up over a foot below the skimmer. Quote Link to comment Share on other sites More sharing options...
icreatepools4u Posted June 28, 2010 Report Share Posted June 28, 2010 Breaking into a slab or pool deck, without positive confirmation of a leak location, is unacceptable. Don’t try to dismantle your pool just to fix the leaks. Fixing a slab leak requires a thorough process with technical expertise, as well as experience. Quote Link to comment Share on other sites More sharing options...
waterbear Posted June 28, 2010 Report Share Posted June 28, 2010 Breaking into a slab or pool deck, without positive confirmation of a leak location, is unacceptable. Don't try to dismantle your pool just to fix the leaks. Fixing a slab leak requires a thorough process with technical expertise, as well as experience. A reputable leak detection company in Houston identified a leak coming off of one of my blowers. Unfortunately the leak is under the pea gravel pool deck. Yes, the leak detection company marked the location of the leak by placing red tape in the form of an X on the pool deck. Apparently its where the line coming off of one of my blowers makes a 90 degree turn. I can definitely fix the leak and then repair the pool deck without a problem. icreatepools4u, sounds like the OP not only knows exactly where the leak is located but also feels they have the knowledge to repair it himself. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 1, 2010 Report Share Posted July 1, 2010 Breaking into a slab or pool deck, without positive confirmation of a leak location, is unacceptable. Don’t try to dismantle your pool just to fix the leaks. Fixing a slab leak requires a thorough process with technical expertise, as well as experience. Did you even read this thread? Quote Link to comment Share on other sites More sharing options...
simple Posted July 3, 2010 Report Share Posted July 3, 2010 posting pics..picture is worth a thousand words.. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted September 21, 2011 Report Share Posted September 21, 2011 However, there are times when larger repairs can take up to a day or more to complete. Depending on the circumstances, major repairs, such as water features or certain plumbing lines, may be referred back to the pool builder for repairs. We take our repair services seriously, and make every effort to ensure you are satisfied with the workmanship of the repair. Before a leak detection or repair is performed, please make sure the water is clean, clear and pool level is full. Pool deck Beverly, Pool deck Middleton Exactly, couldn't agree more. http://www.cmrelectrical.com/water-leak-detection.htm Now kindly take your traveling advertisement show down the road... Quote Link to comment Share on other sites More sharing options...
mattthomas Posted December 15, 2016 Report Share Posted December 15, 2016 Breaking into a slab or pool deck, without positive confirmation of a leak location, is unacceptable. Don’t try to dismantle your pool just to fix the leaks. Fixing a slab leak requires a thorough process with technical expertise, as well as experience. But it is mentioned there that expertise have checked and marked the pool . Then it's done to do the Leak Repair by own. Quote Link to comment Share on other sites More sharing options...
JustinHeber Posted July 6, 2017 Report Share Posted July 6, 2017 You won't try such repairs by own as Leak Detection Contractor have much experience of fixing those leaks perfectly . They will fix it in such a way that those leaks will not be seen in future. So try to fix such repairs by leak detection company. Quote Link to comment Share on other sites More sharing options...
Newb22 Posted July 14, 2017 Report Share Posted July 14, 2017 Something I personally wouldn't attempt to fix but that's just me. I would get the experts to fix it. That could just be me and my non existent DIY skills though. Best of luck. Quote Link to comment Share on other sites More sharing options...
Jacob Stinger Posted October 24, 2017 Report Share Posted October 24, 2017 Unfortunately is such a major break, to the point that it should to be fixed but difficult to figure out which pipe is spilling. How much water would you said you are losing every day? Quote Link to comment Share on other sites More sharing options...
