Bugman1400 Posted May 29, 2010 Report Share Posted May 29, 2010 I got an AquaLinkRS off a friend, but the Thermometers were cut a bit short. It appears that the pink colored cable is a 2-conductor 22 gauge. Can I just solder some new cable to the ends so I can route it to the controller or do I have to buy the whole 7790 Temperature Sensor Kit? Thanks! Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted May 29, 2010 Report Share Posted May 29, 2010 They,(Jandy)say that you can cut the wire, but not add to it. So to me that says don't exceed the distance of the wire that the sensor had when it left the factory. Problem is, i believe that they came in two different lengths. Maybe someone else here knows the distinguishing marks that can identify the length of yours. Or just hook the durn thing up and see if its accurate with your added length of wire. Quote Link to comment Share on other sites More sharing options...
Bugman1400 Posted May 29, 2010 Author Report Share Posted May 29, 2010 They,(Jandy)say that you can cut the wire, but not add to it. So to me that says don't exceed the distance of the wire that the sensor had when it left the factory. Problem is, i believe that they came in two different lengths. Maybe someone else here knows the distinguishing marks that can identify the length of yours. Or just hook the durn thing up and see if its accurate with your added length of wire. Sounds like a plan! I'll report my findings. Quote Link to comment Share on other sites More sharing options...
