webguynow Posted May 26, 2010 Report Share Posted May 26, 2010 I've got rust in the skimmers and quite a bit on the seams and around the top, localized in those areas. I'm wondering if there's a proven fix or procedure, for issues like this. I know it's a big job. see the photos: Pool Pics ~~~~~~~~~ My tentative plan is to strip the paint off the sides, with stripping chemicals and spackle spachula stripper. Then grind and scrape all the rust off possible ( jeez - this could eat thru the seams ) Then treat with naval jelly, even though I hope I won't have or see any more rust. Then prime it, and paint it with marine paint. ( this alone might be $2000+) ~~~~~~~~~ I don't have experience with any of these steps, except for when I tried something like this last year. I think my approach was a little light, and I just had a grinding stone and then used Naval.Jelly, then a Rustoleum paint product. The rust came back and the paint chipped. So I'm looking to do it the 'Right' way this year Anyone have suggestions, references, links, or a procudure/guide I can follow TIA ( Thanks in Advance ) Quote Link to comment Share on other sites More sharing options...
SteveM2690 Posted May 26, 2010 Report Share Posted May 26, 2010 This sounds like a good plan. Just make sure you get all the rust out of the pits and cracks also because within a year the rust could return. In some areas you may have to use some minor sand blasting. Quote Link to comment Share on other sites More sharing options...
webguynow Posted May 27, 2010 Author Report Share Posted May 27, 2010 Kinda curious how far I might have to grind and scrape out to fully remove the rust. If it gets really bad, I will - damage the seams, and then I'd have re-weld ? actually that might get expensive, but sounds like a good solution. Also Should I try to remove all the paint ( the walls are only 5' tall ) Or just let the solid surfaces alone, and remove all the paint from only trouble areas ? if you have input, let me know. thanks Quote Link to comment Share on other sites More sharing options...
LinerMFGr Posted May 28, 2010 Report Share Posted May 28, 2010 ...or you could convert it to a vinyl liner pool. It looks like a pretty straight forward pool--a new liner probably wouldn't cost too much. I imagine it would be a lot cheaper and easier than the process you are suggesting. Good luck. Jeff Quote Link to comment Share on other sites More sharing options...
webguynow Posted May 29, 2010 Author Report Share Posted May 29, 2010 I also notice that the skimmers are quite rusty. They are mounted in the concrete siding and basically are 2 metal boxes, painted and welded together. One box goes horizontally from the main pool to the cavity. And the other goes vertical from deck surface down to the line. Jeez, I got a quote from a pool contractor, and of course the delay, and then the price: $1500/skimmer x 2. I realize these guys have once a year to make their $$$, but With all my issues, did I really need to be gouged ? I note the horizontal metal chamber that comes out to the pool, has a flange that covers over it, and is bolted into the side of the pool. OK? bolted into the steel side, I guess. The other issue, I'm wondering about is, How the bottom of the steel side and the concrete bottom, were attached together to make water tight ? What bond could have been used ? I don't think I'd trust a water-tight seal to a seal of primer and paint. I maybe resurfacing the steel area near the bottom, and it's quite possible I will need to reseal it. Quote Link to comment Share on other sites More sharing options...
