tas Posted April 16, 2010 Report Share Posted April 16, 2010 New member and pool novice here. Any help gratefully accepted. Wondering how i set up my Baracuda pool cleaner. Do I remove the filter basket from within the skimmer and plug it in there? This is what the instructions seem to say. My only confusion with this is that all the dirt from the bottom of the pool will therefore go directly into the filter. Is this correct or am I missing something? Quote Link to comment Share on other sites More sharing options...
jughead Posted April 17, 2010 Report Share Posted April 17, 2010 yah if you do not have a dedicated line for the cleaner with a vac lock then you connect it to the back hole of the skimmer using the regulator to adjust cuda and skimmer suction . also with suction cleaners the dirt does go to the filter Quote Link to comment Share on other sites More sharing options...
tas Posted April 18, 2010 Author Report Share Posted April 18, 2010 yah if you do not have a dedicated line for the cleaner with a vac lock then you connect it to the back hole of the skimmer using the regulator to adjust cuda and skimmer suction . also with suction cleaners the dirt does go to the filter Perfect, thanks. Managed to get it working today! Quote Link to comment Share on other sites More sharing options...
