Okira Posted March 30, 2010 Report Share Posted March 30, 2010 We seem to have a leak in our pool pump, but I can't figure out what the problem is. When the pump is turned off there is no leaking, but after it's been running for a bit, there is water under the skimmer basket. I'd love to fix this myself, but I'm not sure what to do! Someone (pool repair man) told me I need a new pump, but I'm doubting this. Thanks! Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted March 30, 2010 Report Share Posted March 30, 2010 What kind of pump is this Quote Link to comment Share on other sites More sharing options...
Jamie Snyder Posted March 30, 2010 Report Share Posted March 30, 2010 We seem to have a leak in our pool pump, but I can't figure out what the problem is. When the pump is turned off there is no leaking, but after it's been running for a bit, there is water under the skimmer basket. I'd love to fix this myself, but I'm not sure what to do! Someone (pool repair man) told me I need a new pump, but I'm doubting this. Thanks! can you post a picture of it or model # Quote Link to comment Share on other sites More sharing options...
Okira Posted March 30, 2010 Author Report Share Posted March 30, 2010 I have NO clue how to add a picture! Let me know and I'll do it immediately. Thanks! Quote Link to comment Share on other sites More sharing options...
Okira Posted March 30, 2010 Author Report Share Posted March 30, 2010 I have NO clue how to add a picture! Let me know and I'll do it immediately. Thanks! Here is a link to the pump. http://www.poolcenter.com/pumps_SUPERPUMP_poolstor.htm Quote Link to comment Share on other sites More sharing options...
jughead Posted March 31, 2010 Report Share Posted March 31, 2010 probably leaking fron the shaft seal or seal plate o-ring . find a reasonable pool guy to do it i would not recommend you do it your self . and if you let them know what you have ( hayward model ... ) and you think it might be the shaft seal and seal plate o-ring then it might save you money because they can pick up the seals and do the job in one visit . before yopu call the pool guy check and see if the seal plate bolts are not loose . Quote Link to comment Share on other sites More sharing options...
Okira Posted March 31, 2010 Author Report Share Posted March 31, 2010 probably leaking fron the shaft seal or seal plate o-ring . find a reasonable pool guy to do it i would not recommend you do it your self . and if you let them know what you have ( hayward model ... ) and you think it might be the shaft seal and seal plate o-ring then it might save you money because they can pick up the seals and do the job in one visit . before yopu call the pool guy check and see if the seal plate bolts are not loose . Thanks!! My hubby is pretty good with fixing things, but is this a tough job? Quote Link to comment Share on other sites More sharing options...
poolaidman Posted April 2, 2010 Report Share Posted April 2, 2010 probably leaking fron the shaft seal or seal plate o-ring . find a reasonable pool guy to do it i would not recommend you do it your self . and if you let them know what you have ( hayward model ... ) and you think it might be the shaft seal and seal plate o-ring then it might save you money because they can pick up the seals and do the job in one visit . before yopu call the pool guy check and see if the seal plate bolts are not loose . Thanks!! My hubby is pretty good with fixing things, but is this a tough job? I sent you a message with the parts you will need to fix it Quote Link to comment Share on other sites More sharing options...
jose Posted April 13, 2010 Report Share Posted April 13, 2010 probably leaking fron the shaft seal or seal plate o-ring . find a reasonable pool guy to do it i would not recommend you do it your self . and if you let them know what you have ( hayward model ... ) and you think it might be the shaft seal and seal plate o-ring then it might save you money because they can pick up the seals and do the job in one visit . before yopu call the pool guy check and see if the seal plate bolts are not loose . Thanks!! My hubby is pretty good with fixing things, but is this a tough job? I sent you a message with the parts you will need to fix it I had a similiar issue and ended up just taking the motor to a local pool dealer. They repaired the problem with no labor charges. Just charged for the parts. If you have a Leslie Pool near you , they offer the same service. Quote Link to comment Share on other sites More sharing options...
