mag357 Posted March 2, 2010 Report Share Posted March 2, 2010 What do you do when the Alk in a bit low? Every thing else looks ok. The free chlorine is very high so I turn the salt system down to 10%. Any help on this? Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted March 2, 2010 Report Share Posted March 2, 2010 What are all of your readings? Quote Link to comment Share on other sites More sharing options...
mag357 Posted March 2, 2010 Author Report Share Posted March 2, 2010 What are all of your readings? I don't have one of those testing equipment I usually take the water at a pool supply place and have it tested. What I used in this instant was the test strip. It just said the free chlorine was high, the Alk was very low the ph was border line. Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted March 2, 2010 Report Share Posted March 2, 2010 You can't manage your water using test strips. You need accurate readings for the following to decide what to do: Free Chlorine Combined Chlorine pH Total Alkalinity Calcium Hardness Cyanuric acid. Salt Borate Water temperature CSI If your chlorine is too high, you need to turn your chlorinator off. Quote Link to comment Share on other sites More sharing options...
mag357 Posted March 2, 2010 Author Report Share Posted March 2, 2010 quantumchromodynamics, thanks for your help. I will take sample of the water and have it tested and the pool supply place I usually take it. Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted March 3, 2010 Report Share Posted March 3, 2010 I highly recommend that you get your own test kit. Quote Link to comment Share on other sites More sharing options...
