mattmattmatt Posted February 24, 2010 Report Share Posted February 24, 2010 It sounds like the Dichlor then Bleach method would be the least expensive way of doing things so right now I'm leaning in that direction. I'm just trying to figure out (from someone who isn't trying to sell me anything) what I need to keep on hand. My goodness it's confusing! What sort of monthly costs could I expect from various methods assuming an average of about 10 bather/hours per week? I ask this because I was looking at chemical kits that are about $90 for what they say is a 3 month supply and then couple that with the increased electic usage... If I decide to go with simple instead of cheap, what are the options for a novice? Thanks! Quote Link to comment Share on other sites More sharing options...
mattmattmatt Posted February 24, 2010 Author Report Share Posted February 24, 2010 And to add a "wildcard" to the mix, the dealer said they could put in an Ozonator for $300... Honestly, even after reading this forum for the past week, I have no clue what's going on and if the Ozonator is worth it. Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted February 24, 2010 Report Share Posted February 24, 2010 Forget the $90.00 chemical kits. Just follow Nitro's Approach to Water Maintenance You will only need a few basic chemicals and your costs will be a few dollars a month. You will need 1 or 2 pounds of dichlor. That will get you 5 to 10 refills on a 400 gallon tub. At about 4 to 6 months per fill. Dichlor $13.89 for 2 pounds will last for about 50 months. = about $0.28 per month (That's 28 cents per month) You will need a 96 ounce bottle of regular, unscented Clorox bleach. Perhaps about 4 ounce per day = about $2.00 per month. You might need a quart of muriatic acid, 1 pound of baking soda and an 8 pound bottle of Boric acid about $30.00 enough to do 5 refills You should be able to manage on about $3.50 per month. Check out thepoolcalculator You don't have to decide between simple and cheap. The simplest way is the best and cheapest way. Also, do not use test strips. Get a good test kit. This is the most important rule. Quote Link to comment Share on other sites More sharing options...
Dietitian Posted February 25, 2010 Report Share Posted February 25, 2010 And to add a "wildcard" to the mix, the dealer said they could put in an Ozonator for $300... Honestly, even after reading this forum for the past week, I have no clue what's going on and if the Ozonator is worth it. I am very happy with mine, as it has helped keep combined chlorine to near zero after its installation. There is a strong one available on Amazon for $60 and it should take about an hour to install it -- ask the pool guy what his hourly rate is and if he'd be willing to install one that you purchased online. I have found that using the dry chlorine and dry acid powder from Walmart is easier and less messy than using household bleach; it is more expensive but not by much. You can also purchase the large bottles of dry powders that are designed for swimming pools -- they are the same chemicals at much lower cost. I'd also recommend having a defoamer and an enzyme solution on hand just in case someone gets some soap residue in the water, along with "Spa Flush" for when you are ready to drain and refill the spa. You'll also want to order an alternate filter so that you can swap in a new one and clean the old one overnight periodically, and TSP (trisodium phosphate) for cleaning the filter. In summary I would recommend purchasing the following items now: Chlorine (most use dichlor then bleach, I use powdered CYA and chlorine) Dry acid Baking soda Boric acid Defoamer Enzyme solution Spa Flush Filter Trisodium phosphate I got my TSP here: http://cgi.ebay.com/1lb-Trisodium-Phosphat...=item414b3cf6d1 Boric acid here: http://cgi.ebay.com/1-lb-Tech-Grade-Granul...=item35a65a91fb Ozonator: http://www.amazon.com/Spa-109-Hot-Ozonator...9340&sr=8-5 Spa Flush: http://cgi.ebay.com/Spa-System-Flush-2-PAC...=item4ce81d4d17 Enzyme solution: http://cgi.ebay.com/Leisure-Time-Spa-Hot-T...=item27af21f930 Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted February 25, 2010 Report Share Posted February 25, 2010 I have found that using the dry chlorine and dry acid powder from Walmart is easier and less messy than using household bleach; it is more expensive but not by much. What is the actual chemical in the dry chlorine? Quote Link to comment Share on other sites More sharing options...
Dietitian Posted February 26, 2010 Report Share Posted February 26, 2010 I have found that using the dry chlorine and dry acid powder from Walmart is easier and less messy than using household bleach; it is more expensive but not by much. What is the actual chemical in the dry chlorine? calcium hypochlorite Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted February 26, 2010 Report Share Posted February 26, 2010 You have to be careful with calcium hypochlorite because it adds calcium. If you are not careful, your CSI could get too high and cause calcium carbonate scaling. Quote Link to comment Share on other sites More sharing options...
