RDspaguy Posted January 4, 2021 Report Share Posted January 4, 2021 No. Notice it says "clormax technology". You want plain bleach, which is becoming harder to find lately. Or you can just buy pool liquid chlorine, as it's literally made for this... https://www.rspool.com/page220.html Quote Link to comment Share on other sites More sharing options...
nmiller0113 Posted January 4, 2021 Report Share Posted January 4, 2021 Thank you @RDspaguy! I'm assuming that won't impact my CYA like a dichlor would, correct? Also, what do I select in the pool calculator effects to determine my needs? Thanks again! Quote Link to comment Share on other sites More sharing options...
waterbear Posted January 4, 2021 Report Share Posted January 4, 2021 18 hours ago, nmiller0113 said: Quick question, is this the Clorox that @Nitro was referring to? Basically yes. It is a 6% sodium hypochlorite with added water clarifiers to prevent dirt from depositing back on clothes in the laundry. However, these very same chemicals are also used as water clarifiers in pools and spas so they will have no negative impact. House brand bleach is normally cheaper then Clorox and just as effective. I buy bleach at Walmart or the grocery store and buy their brand. However, because of Covid-19 the number of bottles of bleach you can buy is often limited so pool chlorine at 10% or 12.5% might be a more viable option, depending on how much you need. For a spa a one gallon jug will last a long time and you can also use it in the laundry or around the house. Just make sure it's a disinfecting bleach with no scents, thickeners, soaps, or other additives (except Poly(Diallyldimethylammonium Chloride) or Polycrylic acid,which are the clarifiers. Besides sodium hypochlorite and water you will also often find sodium chloride, sodium hydroxide, sodium carbonate, and/or sodium chlorate listed in the ingredients. These are all normal and are either byproducts of manufacture or storage of the product and are nothing to worry about. Quote Link to comment Share on other sites More sharing options...
nmiller0113 Posted January 4, 2021 Report Share Posted January 4, 2021 That's great info @waterbear, thank you again! Quote Link to comment Share on other sites More sharing options...
Joewaterco Posted April 19, 2021 Report Share Posted April 19, 2021 New spa. Sold previous spa. Dichlor just as used before breaking out even after 2 water dumps and shocking Help Quote Link to comment Share on other sites More sharing options...
waterbear Posted April 21, 2021 Report Share Posted April 21, 2021 On 4/19/2021 at 5:35 PM, Joewaterco said: New spa. Sold previous spa. Dichlor just as used before breaking out even after 2 water dumps and shocking Help what kind of help are you asking for? Your post is not clear. Quote Link to comment Share on other sites More sharing options...
Dancemore Posted June 19, 2021 Report Share Posted June 19, 2021 Does this method (for hot tubs) also work with Trichlor? (Trichlor-then-bleach instead of dichlor-then-bleach?) We have a jug of trichlor tabs left we'd like to use up. Thank you! Quote Link to comment Share on other sites More sharing options...
Dancemore Posted June 19, 2021 Report Share Posted June 19, 2021 27 minutes ago, Dancemore said: Does this method (for hot tubs) also work with Trichlor? (Trichlor-then-bleach instead of dichlor-then-bleach?) We have a jug of trichlor tabs left we'd like to use up. Thank you! Some more context: Our city water comes in with a pH of 8+. i’m aware of Chemgeek’s post about Trichlor dissolving fast, lowering pH, and (a plus for us), adding less CYA than dichlor. The tub is old and not under warranty. We’ve had pretty low pH after a year though, yet crisp water just using the stabilized trichloro-s-triazinetrione. So we’ve used Trichlor but never switched over to bleach and I thought of trying that to see if pH will not pull down and wondered if that’s a stupid idea. Thank you for all the solid advice on this forum! Quote Link to comment Share on other sites More sharing options...
waterbear Posted June 19, 2021 Report Share Posted June 19, 2021 11 hours ago, Dancemore said: Our city water comes in with a pH of 8+ What is the total alkalinity of your fill water? IF you are going to run trichllr then your TA should be in the range of 100 to 120 PPM and, because of the aeration from the jets you will need to monitor both pH and TA closely. Once you switch over to bleach you will need to lower the TA to around 50 to 70 ppm. If your initial TA is higher than about 150 ( IMHO is still too high for a spa, IMHO, even when running trichlor) you will need to lower the TA at filling or you will find that your pH will rise too quickly and you will be constantly fighting it. https://www.poolspaforum.com/forum/index.php?/topic/52522-some-truths-about-ph-and-ta/ Quote Link to comment Share on other sites More sharing options...
Dancemore Posted June 24, 2021 Report Share Posted June 24, 2021 On 6/19/2021 at 6:00 AM, waterbear said: What is the total alkalinity of your fill water? IF you are going to run trichllr then your TA should be in the range of 100 to 120 PPM and, because of the aeration from the jets you will need to monitor both pH and TA closely. Once you switch over to bleach you will need to lower the TA to around 50 to 70 ppm. If your initial TA is higher than about 150 ( IMHO is still too high for a spa, IMHO, even when running trichlor) you will need to lower the TA at filling or you will find that your pH will rise too quickly and you will be constantly fighting it. https://www.poolspaforum.com/forum/index.php?/topic/52522-some-truths-about-ph-and-ta/ Our fill water has a TA of 75 with that pH of 8+. Ok, thank you, I raised it to 100 PPM and will try to keep it there until switching to bleach Quote Link to comment Share on other sites More sharing options...
nmiller0113 Posted November 6, 2021 Report Share Posted November 6, 2021 On 1/4/2021 at 11:45 AM, waterbear said: Basically yes. It is a 6% sodium hypochlorite with added water clarifiers to prevent dirt from depositing back on clothes in the laundry. However, these very same chemicals are also used as water clarifiers in pools and spas so they will have no negative impact. House brand bleach is normally cheaper then Clorox and just as effective. I buy bleach at Walmart or the grocery store and buy their brand. However, because of Covid-19 the number of bottles of bleach you can buy is often limited so pool chlorine at 10% or 12.5% might be a more viable option, depending on how much you need. For a spa a one gallon jug will last a long time and you can also use it in the laundry or around the house. Just make sure it's a disinfecting bleach with no scents, thickeners, soaps, or other additives (except Poly(Diallyldimethylammonium Chloride) or Polycrylic acid,which are the clarifiers. Besides sodium hypochlorite and water you will also often find sodium chloride, sodium hydroxide, sodium carbonate, and/or sodium chlorate listed in the ingredients. These are all normal and are either byproducts of manufacture or storage of the product and are nothing to worry about. @waterbear first of all...thank you again for the previous advice you provided. My hot tub has been amazing! I was looking to get more bleach and the previous one I had been purchasing is no longer available. You had mentioned that you bought the cheaper brand so I was wondering if you had a link to that so I could order some? Thank you again and I hope all is well! Quote Link to comment Share on other sites More sharing options...
nmiller0113 Posted November 11, 2021 Report Share Posted November 11, 2021 @waterbear I hate to bother, just wondering if you saw my question above. Thank you again for your help! Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 11, 2021 Report Share Posted November 11, 2021 55 minutes ago, nmiller0113 said: @waterbear I hate to bother, just wondering if you saw my question above. Thank you again for your help! Any brand of (either germicidal or laundry) chlorine bleach without scents, thickeners, or detergents that is 5.25%, 6%, or 8.25% OR liquid pool chlorine that is 10% or 12.5% is fine. It does not to be Clorox brand. House brands from the grocer or big box store are fine as long as their are plain unscented unthickened chlorine bleach or liquid pool chlorine in the strengths listed. Quote Link to comment Share on other sites More sharing options...
nmiller0113 Posted November 24, 2021 Report Share Posted November 24, 2021 On 11/10/2021 at 7:47 PM, waterbear said: Any brand of (either germicidal or laundry) chlorine bleach without scents, thickeners, or detergents that is 5.25%, 6%, or 8.25% OR liquid pool chlorine that is 10% or 12.5% is fine. It does not to be Clorox brand. House brands from the grocer or big box store are fine as long as their are plain unscented unthickened chlorine bleach or liquid pool chlorine in the strengths listed. As usual @waterbear, you’re a great help! I ended up finding one that’s germicidal and generic from Lowe’s 121-fl oz Germicidal Bleach https://www.lowes.com/pd/Style-Selections-121-fl-oz-Germicidal-Bleach/50064623 it has no thickeners or detergents that I can find, and it’s unscented. The side says: Sodium Hypochlorite 6% Other Ingredients 94% Available Chlorine 6% i think that’s exactly what I need. Thank you again and Happy Thanksgiving! Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 24, 2021 Report Share Posted November 24, 2021 Laundry bleach from such places as Walmart or grocery stores is also fine to use as long as it's 5%, 6.25% or 8.25% sodium hypochlorite and it is not scented or thickened. I usually buy bleach at Walmart or my local grocery. In fact, Lowes, Home Depot and my local grocery all stock 10% pool chlorine in my area also. 1 Quote Link to comment Share on other sites More sharing options...
D7m Posted February 24 Report Share Posted February 24 Switched to the bleach method, and have really liked the ease of use so far. Just got the water tested at the pool store: Free Chlorine 0.9ppm, Combined Chlorine 2.2ppm. Would it make sense to shock with bleach up to 22ppm FC? Quote Link to comment Share on other sites More sharing options...
waterbear Posted February 25 Report Share Posted February 25 Quote only if there is no CYA in the water. Post a full set of test results and how they were done (strips, liquid reagents, strips in a reader, liquid or tablet reagents in a reader, dealer testing (and was it liquid reagents or was it discs or strips in a reader) and we can take it from there Quote Link to comment Share on other sites More sharing options...
D7m Posted February 25 Report Share Posted February 25 These are the results of testing done by dealer: Free Chlorine: 0.89ppm Total Chlorine: 3.12ppm Combined Chlorine: 2.23ppm pH 8.2 Alkalinity 122ppm Adjusted Alkalinity 98ppm Calcium Hardness 158ppm CYA 79ppm I have balanced the pH down to 7.4 and the alkalinity has come down with it to about 50ppm. (Tested with Strips) Water has been clear throughout, but I think I must not have added enough bleach after every use. The Original Clorox here in Canada does not state the %Chlorine on the bottle, which is not helpful. Thank you for your thoughts! Quote Link to comment Share on other sites More sharing options...
waterbear Posted February 25 Report Share Posted February 25 1 hour ago, D7m said: These are the results of testing done by dealer are they using strips in a reader, disc in a reader, or liquid reagents or tablets in a reader? 1 hour ago, D7m said: CYA 79ppm This is the red flag. With a CYA of 79 you need to maintain the FC in the 6 to 12 ppm range for normal chlorination with a target of about 9 ppm FC and shock to about 32 ppm to get rid of the combined chloramines and other oxidation byproducts. (FC should be about 8% to 15% of the CYA level, with a target range of 11% to 12% of the CYA. Shock level is about 40% of the CYA level) (Thanks to Chem Geek for determining these levels based on the work of Ben Powell from PoolForum) My suggestion is to drain about about 2/3 of your water and replace it, rebalance, retest , and use the above percentages to determine where to maintain your FC and shock levels based on the CYA level and DO NOT USE A STABILIZED CHLORINE which will add more CYA (Dichlor adds 9 ppm CYA for every 10 ppm FC it adds). Use only unstabilized chlorine (bleach-sodium hypochlorite or lithium hypochlorite a fast dissolving unstabilized chlorine often sold as lithium shock, it's expensive) When you do a full drain and refill use dichlor unti the CYA is about 30 ppm and then switch to bleach. 2 hours ago, D7m said: The Original Clorox here in Canada does not state the %Chlorine on the bottle, which is not helpful. Yeah, they say it's a proprietary secret. However the SDS for original lists it as between 3% - 7 % and the concentrated as between 4% - 9% which leads me to believe they are most likely the same as their US counterparts at 5.25% and 6 or possibly 6% and 7.5%. You can verify this by using the information in the link below and adding enough bleach to produce the values in the link based on the volume of water in YOUR tub and testing about 20 minutes after adding the bleach. For example if you have a 300 gal. tub you would need to add 3 tablespoons bleach to achieve the FC rise shown for each strength of bleach. You should then be able to determine the strength of your bleach, Quote Link to comment Share on other sites More sharing options...
D7m Posted February 25 Report Share Posted February 25 Thank you kindly! I'm sorry, I'm not sure what method the dealer used. I will lower the CYA by draining/refilling partially and will go from there. Earlier in this thread I had read that shocking is not required when using the bleach method. Could you elaborate on that? Thank you once again for all the helpful info! Quote Link to comment Share on other sites More sharing options...
marcbs Posted March 31 Report Share Posted March 31 Newbie here....I recently switched to a salt generator for the tub after loving the experience I have with salt in the big pool. The first fill went ok for a while but started having issues a few weeks in. Minimal bather loads. Couldn't get chlorine levels high enough. TDS climbed to around 1800. Important? Now doing a refill. Is there a proper order to follow for balancing the new water? Is CYA important with salt and how do I adjust it? Dichlor shocks? Do I supplement the salt with dichlor or bleach? Any tips on keeping the balance. I am using the ControlOMatic SmarterSpa salt generator. It senses low chlorine and comes on automatically. I searched for a salt sticky, sorry for all the q's, and thanks in advance for your answers! Quote Link to comment Share on other sites More sharing options...
danbfree Posted June 1 Report Share Posted June 1 So liquid pool chlorine at 10% sodium hypochlorite is literally the same as household bleach, just a bit stronger and without added stabilizers that dichlor and others add? I've been struggling to get CYA levels down after years of putting "whatever" pool chlorine in my spa so I'm going to do a flush and fill and start over using the method on page 1... Quote Link to comment Share on other sites More sharing options...
waterbear Posted June 1 Report Share Posted June 1 There are 2 forms of stabilized chlorine, trichlor and dichlor. Trichlor is very acidic and therefore not recommended for spas. For every 10 ppm of free chlorine (FC) added trichlor adds 6 ppm of CYA. Dichlor is net acidic (acidic on application and had an acidic reaction when it sanitizes) and it is commonly used in hot tubs. For every 10 ppm FC added it add 9 ppm CYA. There are 3 unstabilized chlorine sources, calcium hypochlorite (cal hypo), lithium hypochlorite, and sodium hypochlorite. Calcium hypoclorite is a slow dissolving powder that is basically net neutral (alkaline on addition and acidic reaction when it sanitizes) and it adds 7 ppm calcium hardness for every 10 ppm FC added. Lithium hypochlorite is a fast dissolving power that is net neutral also. It's main drawback is that it is the most epen$ive form of chlorine. Sodium hypochlorite is also a net neutral chlorine source. It is a liquid that commonly available in 10% AND 12.5% strength as liquid pool chlorine or liquid shock. It is also readily available as liquid chlorine laundry bleach (you want the plain, unscented, unthickened type without added detergents or additives). It is commonly available in 5.25% (regular) and 6% (ultra). It is also sometimes sold in 8.25% and 3%. The 3% is often sold at dollar stores and is usually more expensive to use because of the amount needed to reach a specific FC level. Chemically, laundry bleach and pool chlorine are EXACTLY the same except for the strength (just as alkalinity increaser and baking soda are exactly the same since both are sodium bicarbonate AKA sodium hydrogen carbonate). Sometimes Brand Name plain, unscented, unthickened laundry bleach will contain some additional chemicals such as polydiallyldimethylammounium chloride ( Polyquaternium-6) and Sodium polyacrylate to prevent dirt from redepositing on clothes in the wash. These particular additives with not have a negative impact and, in fact, are also the main ingredients in many water clarifiers used in pools and spas. 1 Quote Link to comment Share on other sites More sharing options...
danbfree Posted June 7 Report Share Posted June 7 On 6/1/2022 at 9:14 AM, waterbear said: There are 2 forms of stabilized chlorine, trichlor and dichlor. Trichlor is very acidic and therefore not recommended for spas. For every 10 ppm of free chlorine (FC) added trichlor adds 6 ppm of CYA. Dichlor is net acidic (acidic on application and had an acidic reaction when it sanitizes) and it is commonly used in hot tubs. For every 10 ppm FC added it add 9 ppm CYA. There are 3 unstabilized chlorine sources, calcium hypochlorite (cal hypo), lithium hypochlorite, and sodium hypochlorite. Calcium hypoclorite is a slow dissolving powder that is basically net neutral (alkaline on addition and acidic reaction when it sanitizes) and it adds 7 ppm calcium hardness for every 10 ppm FC added. Lithium hypochlorite is a fast dissolving power that is net neutral also. It's main drawback is that it is the most epen$ive form of chlorine. Sodium hypochlorite is also a net neutral chlorine source. It is a liquid that commonly available in 10% AND 12.5% strength as liquid pool chlorine or liquid shock. It is also readily available as liquid chlorine laundry bleach (you want the plain, unscented, unthickened type without added detergents or additives). It is commonly available in 5.25% (regular) and 6% (ultra). It is also sometimes sold in 8.25% and 3%. The 3% is often sold at dollar stores and is usually more expensive to use because of the amount needed to reach a specific FC level. Chemically, laundry bleach and pool chlorine are EXACTLY the same except for the strength (just as alkalinity increaser and baking soda are exactly the same since both are sodium bicarbonate AKA sodium hydrogen carbonate). Sometimes Brand Name plain, unscented, unthickened laundry bleach will contain some additional chemicals such as polydiallyldimethylammounium chloride ( Polyquaternium-6) and Sodium polyacrylate to prevent dirt from redepositing on clothes in the wash. These particular additives with not have a negative impact and, in fact, are also the main ingredients in many water clarifiers used in pools and spas. Thank you, since our spa never sees any direct sunlight (large umbrella covers it) and only even indirect light when used, maybe 30 min to 1 hr a day I will be using the liquid pool chlorine from now on, just very occasionally using up the dichlor powder to keep a little CYA in there. I can get 10% pool chlorine for the same price as even generic plain 7.5% bleach, so it will be very economical to keep up that way, just a little splash of it after every soak in our little 210 gallon tub. Thanks for clarifying! Quote Link to comment Share on other sites More sharing options...
waterbear Posted June 7 Report Share Posted June 7 Even if it gets very little direct sunlight it's still a good idea to have about 30 ppm CYA since it acts as a "buffer" for the chlorine, making it less agressive on swimsuits and people. Quote Link to comment Share on other sites More sharing options...
