Guest chad Posted September 24, 2005 Report Share Posted September 24, 2005 I have an inground pool with a vinyl liner & I think fiberglass steps.The sides walls of the pool ,the steps,jets,& main drain are stained a brownish-rusty color.The floor of the pool very clean & the water is clear.The chlorine level is good,but the ph level is a little high.The pool was recently very cloudy & green due to bad gaskets in the 8 position valve on top of the sand filter,therefore I had no pressure or vacuum.I changed the gaskets and have regained pressure & vacuum.I"ve since developed the stains.What do i do? Quote Link to comment Share on other sites More sharing options...
Guest Pat Posted September 24, 2005 Report Share Posted September 24, 2005 I take it the stains are right at the water line. They could be caused either by oils or algae. The best would be to purchase a liner cleaner and try scrub it with a sponge (one's with abbrasive side). Be careful that you aren't removing the pattern. If the dirt does not lift from this, contact Vyn-all and ask them for advice. www.vynall.com. Pat Fitzgerald Sunbuilt Pools, Inc. Quote Link to comment Share on other sites More sharing options...
Guest Sarah Posted September 24, 2005 Report Share Posted September 24, 2005 Have your water tested for metals- then do what the company recommends from there- it sounds like a metal stain. If it isn't metals it may be corrosion- what is the total alkalinity reading? Quote Link to comment Share on other sites More sharing options...
Guest Gayle Posted September 24, 2005 Report Share Posted September 24, 2005 We are replacing our 14 year old vinyl in-ground pool liner. What color of liner do you think would be easiest to maintain, show less dirt and hide stains? I would think a medium blue with a small pattern. I am concerned about fading on a dark color. What do you think? Quote Link to comment Share on other sites More sharing options...
Guest maggie Posted September 24, 2005 Report Share Posted September 24, 2005 Hi Sarah, I did not originate this message, but have the same problem. The stains are all around the pool from about 6 inches below the water line and around the inside bottom. Originally, there was algae there and it turned brown when we shocked the pool. We've had the pool for 5 years and this has never happened. I read that you suggested it could be metal or corrosion. How would these stains have originated? Do you think there is a product that would take this out? Where do I go for the products? Maggie Quote Link to comment Share on other sites More sharing options...
