Patrickco Posted September 29, 2009 Report Share Posted September 29, 2009 Hello, I recently purchased a 99 or 00 sundance optima with the sentry 850 control box. It's my first spa so I'm still learning about it. My blower was tripping the GFCI and sure enough it was all corroded and wet when I removed it. I'm in the process of replacing it, but I want to also replace the check valve to prevent a repeat occurence. So here's my dumb question, where is the check valve? I don't really want to go poking around all sides of the spa if someone could just tell me where to look. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
otis_skywalker Posted September 29, 2009 Report Share Posted September 29, 2009 if I remember right, there is not one... it's all hartford loop deal on that one, if you just moved the spa thats probally why it got wet in there... (flipped on it's side to move). Quote Link to comment Share on other sites More sharing options...
Patrickco Posted September 30, 2009 Author Report Share Posted September 30, 2009 That would make sense... I took off a couple panels last night and couldn't find anything obvious. The piping from the blower goes immediately into foam insualtion so if there WAS a check valve in there, it wouldn't be very accessible. And I did recently move the tub, so that would explain the water. Thanks! Quote Link to comment Share on other sites More sharing options...
