Zooming993 Posted September 10, 2009 Report Share Posted September 10, 2009 Our in ground pool (Shotcrete) was completed on 8-5-09. The PB told me to run the equipment for 12 hours a day. Based the following pool details, what should be the minimum run time be per day? •Freeform: 20’ X 40’ •Gallons: 20K •Finish: Diamond Brite •Pump: Jandy Stealth 2hp •Filter: Jandy DEV60 •Chlorinator: Hayward CL220 •Pool Cleaner: Aquabot T4 •location: Northeast Thank you Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted September 10, 2009 Report Share Posted September 10, 2009 I usually tell people, 4 to 6 hours in the winter, 6 to 8 in the summer. But that is in California, where we usually don't close the pool in winter. If, after saying that, the customer looks at me like i'm from the electric company, I tell them to experiment with run times. Sometimes they can get away with shorter run times. It basically comes down to variables that vary from pool to pool. Sorry, but no help. Quote Link to comment Share on other sites More sharing options...
mart242 Posted September 10, 2009 Report Share Posted September 10, 2009 Check on the hayward site, there's a calculator for that. It depends on flow rate and how many water turnover you want per day Quote Link to comment Share on other sites More sharing options...
billp Posted September 10, 2009 Report Share Posted September 10, 2009 •Gallons: 20K •Pump: Jandy Stealth 2hp Unless you own the electric co a 2 hp will cost you a lot to run for 12 hrs/day. And unless you have a spa with 8 jets this pump appears do be oversized. Run time is also a factor of swim load and contaminant load. Experiment is the best answer. You likely have a turnover time of 4 hours. Much higher than necessary on a residential pool. Quote Link to comment Share on other sites More sharing options...
Zooming993 Posted September 10, 2009 Author Report Share Posted September 10, 2009 Thank you for the replies. Quote Link to comment Share on other sites More sharing options...
texasmax Posted September 10, 2009 Report Share Posted September 10, 2009 So if I know my turnover rate, what's an appropriate # of turnovers per day? In Dallas, so just like CA, I run year-round. Quote Link to comment Share on other sites More sharing options...
