Surfbeast Posted August 28, 2009 Report Share Posted August 28, 2009 Hey all, I just installed a new pump. Evrything was working fine. Then I noticed that the temp was about 107F. Temp setting was at 97F. I set the temp down to 80F and today the temp in the tub had climbed to 110F!!! What is wrong and how do I fix it? I'm going out now to boil some shrimp in it. Thanks Quote Link to comment Share on other sites More sharing options...
kimpur Posted August 28, 2009 Report Share Posted August 28, 2009 HA HA!!! Good one! Quote Link to comment Share on other sites More sharing options...
ps558 Posted August 28, 2009 Report Share Posted August 28, 2009 Hey all, I just installed a new pump. Evrything was working fine. Then I noticed that the temp was about 107F. Temp setting was at 97F. I set the temp down to 80F and today the temp in the tub had climbed to 110F!!! What is wrong and how do I fix it? I'm going out now to boil some shrimp in it. Thanks Do you have any prgrammable filter cycles? Does the pump ever shut off? What brand or controls does it have? Quote Link to comment Share on other sites More sharing options...
n1oty Posted August 28, 2009 Report Share Posted August 28, 2009 Hey all, I just installed a new pump. Evrything was working fine. Then I noticed that the temp was about 107F. Temp setting was at 97F. I set the temp down to 80F and today the temp in the tub had climbed to 110F!!! What is wrong and how do I fix it? I'm going out now to boil some shrimp in it. Thanks Have you checked for voltage and amperage draw at the heater? If you have full voltage, I'd suspect a stuck relay. If you don't, check your filtration times. If neither of these solves your problem, check the heater for a ground fault. John Quote Link to comment Share on other sites More sharing options...
Surfbeast Posted August 29, 2009 Author Report Share Posted August 29, 2009 The pump cycles on and off like it should. It does not stay on continuously. It does not have any programmable filter cycles, it does it on it's own program and heater kicks on when it falls below set temp. I'm going to check all the wires. just seems funny that it does read the set temp and the actual tub temp. It's just not turning off at the set temp, a bad heater should not cause this should it? Also, the Overheat sensor should have turned the tub off, should'nt it?? Thanks Quote Link to comment Share on other sites More sharing options...
mrfixit Posted August 29, 2009 Report Share Posted August 29, 2009 Usually, the hi limit shut off will kick in about 108 to 110. I suspect that either the temp sensor is bad or there is a bad temp button on the control pad. Are there any issues in the control pad, like moisture in the display or buttons not working? If so, that may be the source of the trouble. try turning the temp way down, like to 85 or something like that and see if it continues to heat. That may be an indicator of what was mentioned above; ie a stuck relay . Do not let the temp get above 110 or you will experience melting plumbing, then you will have real problems. let us know how it goes. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted August 29, 2009 Report Share Posted August 29, 2009 One vote for stuck relay... Quote Link to comment Share on other sites More sharing options...
Peteyboy Posted August 29, 2009 Report Share Posted August 29, 2009 2 votes for stuck relay. Quote Link to comment Share on other sites More sharing options...
Surfbeast Posted August 29, 2009 Author Report Share Posted August 29, 2009 Where would this relay be?? In the control panel or is it a sensor like he one that is attached to the outside of the heater tube. Quote Link to comment Share on other sites More sharing options...
n1oty Posted August 29, 2009 Report Share Posted August 29, 2009 Where would this relay be?? In the control panel or is it a sensor like he one that is attached to the outside of the heater tube. If you have a PC board, it is on the board. If you do not have a PC board, it is a separate relay in the box. John Quote Link to comment Share on other sites More sharing options...
HTLover Posted April 29, 2012 Report Share Posted April 29, 2012 I am experiencing similar problems. Did you ever find a solution? my relay/contactor releases when power is disconnected at the house. Quote Link to comment Share on other sites More sharing options...
