mag357 Posted August 3, 2009 Report Share Posted August 3, 2009 I have a Jandy spa light in my spa, (white only), is it difficult to change the bulb? Quote Link to comment Share on other sites More sharing options...
ps558 Posted August 3, 2009 Report Share Posted August 3, 2009 I have a Jandy spa light in my spa, (white only), is it difficult to change the bulb? No it pretty simple. If installed correctly with water in the spa. Turn the power off. There should be a screw near the center of the lights outer ring. Loosen the screw and it should come out of the niche with enough cord to reach the spa deck. You could also drain the spa. With the light out there is a band with a bolt or screws that hold it together. Remove that and now you have access to the bulb. Replace the bulb with a exact same rating. If it halogen bulb do not touch it with bare hands. Reassemble the light asseambly, but before putting it back into the niche hold under some water and look for air bubbles. No bubbles wrap the cord around it and return it the light niche. if you have air bubbles or the inside of the light in damp, you will need to replace the gasket Quote Link to comment Share on other sites More sharing options...
mag357 Posted August 3, 2009 Author Report Share Posted August 3, 2009 I have a Jandy spa light in my spa, (white only), is it difficult to change the bulb? No it pretty simple. If installed correctly with water in the spa. Turn the power off. There should be a screw near the center of the lights outer ring. Loosen the screw and it should come out of the niche with enough cord to reach the spa deck. You could also drain the spa. With the light out there is a band with a bolt or screws that hold it together. Remove that and now you have access to the bulb. Replace the bulb with a exact same rating. If it halogen bulb do not touch it with bare hands. Reassemble the light asseambly, but before putting it back into the niche hold under some water and look for air bubbles. No bubbles wrap the cord around it and return it the light niche. if you have air bubbles or the inside of the light in damp, you will need to replace the gasket Thanks very much for your reply, sounds simple enough. I have to make sure and get the right bulb. Thanks again for your help. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted August 4, 2009 Report Share Posted August 4, 2009 I don't have very much luck with the lens gaskets after they have been tightened down once. You might want to change it just to be sure. You can also change the wattage if you don't like getting blasted by the 4 or 5 hundred watt bulb. You can get 100 watt bulbs (flood light type). It tones down the brightness a bit and matches better (brightness) with the pool light when you use them both. Quote Link to comment Share on other sites More sharing options...
