These Are The Numbers, Where Do I Go From Here?
sjt2900
Because the CH was between 450-500 we drained the tub and refilled with soft water. I added Calcium Chloride until I thought the hardness was right and then tried to work on the other factors. This took a couple of days and everything seemed to be ok. We were in the tub once 2 days ago. Then I check it tonight and get this.
FC=2.0
CC=0.5
PH=7.6
AK=50
CH=110
CYA=Less than 30. The tube filled up and never did get cloudy
I've never had the AK be low. I always had the problem of it being high before we filled with soft water. And what's up with the CYA? I'm not sure what to think about that. And should the CC be 0.5 after only being in the tub once? Honestly, we were clean when we got in it.
