Sundance Optima Oh Display And High Heat Shutoff
My 2004 Sundance Optima has begun having issues
It shuts down - we shut off the power for awhile
turn it back on - temp will show 97 o 98 degrees
within 10 minutes, temps start rising on display
then the OH display shows up and the tub shuts down at
112 degrees or so
Any ideas anyone?
Thanks
Steve
112 degrees or so
Any ideas anyone?
Thanks
Steve
My first question would be, "Is the water temperature actually rising to 112?"
You may have a problem with little or no circulation through the heater. In other words, you could have a blockage or a pump which simply isn't functioning properly, and thereby when the heater turns on, it's heating just the water inside itself. This will ultimately heat up very high and trigger the "High Limit" safety on your spa. Now, if the water in the hot tub itself is actually getting that hot, you may have a problem with the thermostat in the hot tub itself (which is why there's a separate high limit safety).
That's just my guess. :) Does your Sundance have the optional circulation pump, or does it use the jet pump to cycle water?
112 degrees or so
Any ideas anyone?
Thanks
Steve
Thanks
The tub does have the circulation pump - is it possibly the temp sensor?
steve
112 degrees or so
Any ideas anyone?
Thanks
Steve
I had the same problem 2x on my 2003 Cameo.. Sorry, but I can't remember if it was a bad sensor/board/pump as the dealer just came out and fixed it both times. :(
It would show 112, but the tub was really like 98.
