kammiejoy Posted June 18, 2009 Report Share Posted June 18, 2009 I have been using a nature2 minteral cartridge for about 3 months, and when I went to replace it, it looked like this: Nature2 Mineral Cartridge Does anyone know why this might be happening? Thanks, Kammie Quote Link to comment Share on other sites More sharing options...
DonR6702 Posted June 18, 2009 Report Share Posted June 18, 2009 I have been using a nature2 minteral cartridge for about 3 months, and when I went to replace it, it looked like this: Nature2 Mineral Cartridge Does anyone know why this might be happening? Thanks, Kammie Hi Kammie, I can't be sure just by looking at the photo, but that looks like it could be "soap scum", which is produced in a spa that has low hardness, pH and/or alkalinity. Is that residue sort of soft and flaky or gooey, or is it hard and brittle? I assume you're using chlorine as a primary sanitizer, is that right? Any issues with water clarity? Don Quote Link to comment Share on other sites More sharing options...
kammiejoy Posted June 18, 2009 Author Report Share Posted June 18, 2009 I have been using a nature2 minteral cartridge for about 3 months, and when I went to replace it, it looked like this: Nature2 Mineral Cartridge Does anyone know why this might be happening? Thanks, Kammie Hi Kammie, I can't be sure just by looking at the photo, but that looks like it could be "soap scum", which is produced in a spa that has low hardness, pH and/or alkalinity. Is that residue sort of soft and flaky or gooey, or is it hard and brittle? I assume you're using chlorine as a primary sanitizer, is that right? Any issues with water clarity? Don Hi Don, Thanks for your quick reply. Here are some answers to your questions. The residue on the cartridge is hard and brittle. We do not use chlorine or bromine in the tub...just the mineral cartridge and a spa shock oxidizer once a week (the hot tub also has an ozonator). We have not had any issues with water clarity. Kammie Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted June 18, 2009 Report Share Posted June 18, 2009 First, Nature 2 requires that you jump start with chlorine, then you can use non chlorine shock. Hard and brittle is usually a scale build up.(scale will seek metals to attach to, this includes your heater!) Have your Alk and PH levels been in check? What is the calcium hardness in the tub? Is this well water? So many questions, but many things can cause scale issues. Quote Link to comment Share on other sites More sharing options...
kammiejoy Posted June 19, 2009 Author Report Share Posted June 19, 2009 First, Nature 2 requires that you jump start with chlorine, then you can use non chlorine shock. Hard and brittle is usually a scale build up.(scale will seek metals to attach to, this includes your heater!) Have your Alk and PH levels been in check? What is the calcium hardness in the tub? Is this well water? So many questions, but many things can cause scale issues. Thanks for the information. It is not well water and the alk and ph levels have been in check, but I haven't been testing the calcium hardness. The original test strips we got with the tub do not have a test for hardness. I will get on that. Quote Link to comment Share on other sites More sharing options...
