smhbuyer 1 Posted June 13, 2009 Report Share Posted June 13, 2009 The last couple of nights when we have gotten in our tub the seats have felt slimey to the touch. The water appears to be in balance. PH is a little higher than it has been but still in normal range. I did use one of those fragrance pouches, but it was made for hot tubs and stated that it would not effect the balance. What do you think it could be and how can we fix it?? Quote Link to post Share on other sites
rentit 0 Posted June 13, 2009 Report Share Posted June 13, 2009 The last couple of nights when we have gotten in our tub the seats have felt slimey to the touch. The water appears to be in balance. PH is a little higher than it has been but still in normal range. I did use one of those fragrance pouches, but it was made for hot tubs and stated that it would not effect the balance. What do you think it could be and how can we fix it?? Maintain your chlorine level at all times. Quote Link to post Share on other sites
DonR6702 0 Posted June 13, 2009 Report Share Posted June 13, 2009 The last couple of nights when we have gotten in our tub the seats have felt slimey to the touch. The water appears to be in balance. PH is a little higher than it has been but still in normal range. I did use one of those fragrance pouches, but it was made for hot tubs and stated that it would not effect the balance. What do you think it could be and how can we fix it?? What sanitizer are you using? If you're using biguanide (e.g., BaquaSpa, SoftSwim) this a fairly normal phenomenom and nothing to be concerned about. BaquaSpa sanitizer (and probably the other biguanide spa and pool sanitizers) seem to contain a little surfactant (i.e., detergent or related compound) that tends to make things feel a little slippery. The surfactant is there to help minimize the buildup of scummy biguanide deposits at the waterline. It also accounts for the tendency of BaquaSpa-treated spas to turn milky white when the pumps are on high with air injection. This is due to millions of micro-bubbles produced by the injected air and facilitated by the surfactant. A lot of people really like the silky feel of biguanide-treated spa water. I used BaquaSpafor a couple of years but finally switched to chlorine. Don Quote Link to post Share on other sites
smhbuyer 1 Posted June 13, 2009 Author Report Share Posted June 13, 2009 The last couple of nights when we have gotten in our tub the seats have felt slimey to the touch. The water appears to be in balance. PH is a little higher than it has been but still in normal range. I did use one of those fragrance pouches, but it was made for hot tubs and stated that it would not effect the balance. What do you think it could be and how can we fix it?? What sanitizer are you using? If you're using biguanide (e.g., BaquaSpa, SoftSwim) this a fairly normal phenomenom and nothing to be concerned about. BaquaSpa sanitizer (and probably the other biguanide spa and pool sanitizers) seem to contain a little surfactant (i.e., detergent or related compound) that tends to make things feel a little slippery. The surfactant is there to help minimize the buildup of scummy biguanide deposits at the waterline. It also accounts for the tendency of BaquaSpa-treated spas to turn milky white when the pumps are on high with air injection. This is due to millions of micro-bubbles produced by the injected air and facilitated by the surfactant. A lot of people really like the silky feel of biguanide-treated spa water. I used BaquaSpafor a couple of years but finally switched to chlorine. Don We use Nature 2, add chlorine once a week and shock weekly on a different day (per the dealers instructions). With this sanitizer, do you think we have nothing to be concerned with? Quote Link to post Share on other sites
rentit 0 Posted June 14, 2009 Report Share Posted June 14, 2009 Seriously, Maintain your chlorine level at all times. Quote Link to post Share on other sites
DonR6702 0 Posted June 14, 2009 Report Share Posted June 14, 2009 We use Nature 2, add chlorine once a week and shock weekly on a different day (per the dealers instructions). With this sanitizer, do you think we have nothing to be concerned with? I'm really not familiar with the Nature 2 system. It's still important though to keep a chlorine residual in the water, and it seems to me that if you're trying to keep it low, around 0.5 ppm as the manufacturer suggests, you may need to add it more than once a week. How much do you add when you shock? Quote Link to post Share on other sites
tony 0 Posted June 14, 2009 Report Share Posted June 14, 2009 We use Nature 2, add chlorine once a week and shock weekly on a different day (per the dealers instructions). With this sanitizer, do you think we have nothing to be concerned with? The slimy feel is most likely due to lack of sanitizer. I personally would never suggest the routine you are using. Use of Nature2 either requires a lot of MPS each time you use the spa and a chlorine shock weekly or a little chlorine after each use and either a chlorine or MPS shock weekly. Nature2 is a very slow bacteriacide and is easily overcome by even just one bather. Chlorine is fast acting but does not last long. MPS along with Nature2 apparently works but you need to add lots of MPS when spa is in use. Chlorine and MPS once per week each is way too little sanitizer, IMO. Quote Link to post Share on other sites
smhbuyer 1 Posted June 15, 2009 Author Report Share Posted June 15, 2009 Thank you Don, Tony and rentit...actually you were all right. We added our weekly chlorine on Friday and the problem was gone on Saturday. We are going to increase the frequency that we add the chlorine and continue to do the weekly shock. Gotta tell you...I love this forum!!! Where else can you get such a such a service for free...accurate, informative, friendly and fast. Thanks so much!! 1 Quote Link to post Share on other sites
rentit 0 Posted June 15, 2009 Report Share Posted June 15, 2009 Thank you Don, Tony and rentit...actually you were all right. We added our weekly chlorine on Friday and the problem was gone on Saturday. We are going to increase the frequency that we add the chlorine and continue to do the weekly shock. Gotta tell you...I love this forum!!! Where else can you get such a such a service for free...accurate, informative, friendly and fast. Thanks so much!! Do the stuff you mention and you will be in great shape! Quote Link to post Share on other sites
spdztr 1 Posted June 9, 2020 Report Share Posted June 9, 2020 Hate to resurrect an old thread, but I am new and my search for this topic came up with this discussion. I have the same issue, but I'm using bromine tablets instead of chlorine. PH levels were a bit high so just waiting for that to settle. Also shocked it earlier this week to try and help. We just got the tub 2 weeks ago and have been trying to learn! Any suggestions for getting rid of the slime in a bromine-based tub would be greatly appreciated!! 1 Quote Link to post Share on other sites
RDspaguy 642 Posted June 9, 2020 Report Share Posted June 9, 2020 You should use Ahh-Some spa purge to clear up the gunk in your pipes any time you get a new or used spa. Then start a new thread with info on YOUR spa maintenance routine, including ozone and mineral purifiers. Here is some info that might help. https://taylortechnologies.com/en/page/123/whats-best-for-a-spa-chlorine-or-bromine Quote Link to post Share on other sites
welovethebeach 0 Posted December 17, 2020 Report Share Posted December 17, 2020 On 6/9/2020 at 4:33 PM, spdztr said: Hate to resurrect an old thread, but I am new and my search for this topic came up with this discussion. I have the same issue, but I'm using bromine tablets instead of chlorine. PH levels were a bit high so just waiting for that to settle. Also shocked it earlier this week to try and help. We just got the tub 2 weeks ago and have been trying to learn! Any suggestions for getting rid of the slime in a bromine-based tub would be greatly appreciated!! We are having the exact same issue! Also using Bromine. Any answers yet? Kim Quote Link to post Share on other sites
RDspaguy 642 Posted December 18, 2020 Report Share Posted December 18, 2020 Simply put, the slime is the result of low sanitizer. There are a few issues that can lead to that, but that's the cause. Use Ahhsome spa cleaner an maintain appropriate sanitizer residuals. Quote Link to post Share on other sites
