Chaseript Posted April 8, 2009 Report Share Posted April 8, 2009 Hello - I have a Jandy Aqualink with 2 issues: 1) the pool water temp is always above 100 degrees F, even in dead of winter - but I don't get any type of error message. 2) this morning I noticed the filter and cleaner were still running 2 hrs after scheduled finish time. Date/time settings and program settings are still intact, and there has been no power outage. The troubleshooting guide says to check the battery, and/or to clear the programs and reset. I turned the cleaner off at the controller this AM, and it shut off both the cleaner and the filter. About 2 hrs later, they both turned on again. Any thoughts or suggestions? thank you, Mike Quote Link to comment Share on other sites More sharing options...
poolvibe Posted April 8, 2009 Report Share Posted April 8, 2009 Hello - I have a Jandy Aqualink with 2 issues: 1) the pool water temp is always above 100 degrees F, even in dead of winter - but I don't get any type of error message. 2) this morning I noticed the filter and cleaner were still running 2 hrs after scheduled finish time. Date/time settings and program settings are still intact, and there has been no power outage. The troubleshooting guide says to check the battery, and/or to clear the programs and reset. I turned the cleaner off at the controller this AM, and it shut off both the cleaner and the filter. About 2 hrs later, they both turned on again. Any thoughts or suggestions? thank you, Mike Its a bad logic board... Quote Link to comment Share on other sites More sharing options...
Chaseript Posted April 8, 2009 Author Report Share Posted April 8, 2009 Hello - I have a Jandy Aqualink with 2 issues: 1) the pool water temp is always above 100 degrees F, even in dead of winter - but I don't get any type of error message. 2) this morning I noticed the filter and cleaner were still running 2 hrs after scheduled finish time. Date/time settings and program settings are still intact, and there has been no power outage. The troubleshooting guide says to check the battery, and/or to clear the programs and reset. I turned the cleaner off at the controller this AM, and it shut off both the cleaner and the filter. About 2 hrs later, they both turned on again. Any thoughts or suggestions? thank you, Mike Its a bad logic board... thanks very much. Is there another name for logic board, I'm not seeing that term here. Also, is this a part I can buy and install, or do I have to call in a pro? Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted April 9, 2009 Report Share Posted April 9, 2009 It's call a bezel. Jandy says those things are kinda bullet proof. What goes bad is the chip. I would try replacing the temp sens first (cheaper). You wouldn't necessarily get a error msg while still getting a temp reading. The sensor may have just "slid" a little out of tolerance, not quite open yet. Quote Link to comment Share on other sites More sharing options...
jgskid Posted April 13, 2009 Report Share Posted April 13, 2009 I agree with the temperature sensor idea as I have had mine fail twice. You can check the resistance and check it against a published table from Jandy or perhaps you can even disconect it. I have had strange problems such as you describe with things turning on and off by themselves when my separate spa-side 4 button switches short out which they do every few years. Quote Link to comment Share on other sites More sharing options...
