This topic comes up quite a bit. I explain the process in my Maintenance Guide, but I thought I'd post a separate thread for easy reference. I won't get into detail why you would want to do this here. See my guide for more info. I will say this, the key is, you should NOT focus on adjusting pH directly. Instead, you should focus on adjusting TA to an ideal level, in order to keep your pH in line.
The problem with lowering Total Alkalinity (TA) is that when you add acid to lower TA, pH also dec
