Pool Clown Posted March 13, 2009 Report Share Posted March 13, 2009 How is the light accessed? From the water side? Or the from back? I'm looking at replacing with led bulb. 2000 altamar. Quote Link to comment Share on other sites More sharing options...
ps558 Posted March 13, 2009 Report Share Posted March 13, 2009 How is the light accessed? From the water side? Or the from back? I'm looking at replacing with led bulb. 2000 altamar. In the control bay is access to replace the bulb to a LED one. You will need to remove the plastic cap in the back of the lenses to install a LED. some pull off, some are threaded Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted March 15, 2009 Author Report Share Posted March 15, 2009 Thanks Five five eight, Can you tell which one I have? I know it's not much of a view. The plywood you see is the back board for the pack and pretty much blocks any access. The view you see here, is it for access. Quote Link to comment Share on other sites More sharing options...
djousma Posted March 23, 2009 Report Share Posted March 23, 2009 Thanks Five five eight, Can you tell which one I have? I know it's not much of a view. The plywood you see is the back board for the pack and pretty much blocks any access. The view you see here, is it for access. Looks like you can see just the end of the bulb socket at the end of those two black wires. As mentioned, you replace from the backside. some just pull out, some are a quarter turn, some are threaded. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted March 27, 2009 Author Report Share Posted March 27, 2009 Looks like you can see just the end of the bulb socket at the end of those two black wires. As mentioned, you replace from the backside. some just pull out, some are a quarter turn, some are threaded. Which type do I have? Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted March 27, 2009 Author Report Share Posted March 27, 2009 I screwed with it some more and I have the threaded kind. Quote Link to comment Share on other sites More sharing options...
djousma Posted March 31, 2009 Report Share Posted March 31, 2009 I screwed with it some more and I have the threaded kind. Sorry been away for a few days. so you got the socket out. the new LED light upgrade should just plug into the socket, and then you just put the whole thing back in. You should be good to go... Quote Link to comment Share on other sites More sharing options...
