ManuBoy808 Posted January 30, 2009 Report Share Posted January 30, 2009 I do not, for the life of me, know how to read the results of the litmus strips when i test the water. It works..the colors change, but in my opinion, its not clear as to which color is which. I cant tell if its low or high or in the middle. Some of the colors look like they can be a few different ones. Any advice for this? Is there some type of "digital" tester I could use? Quote Link to comment Share on other sites More sharing options...
tony Posted January 31, 2009 Report Share Posted January 31, 2009 I do not, for the life of me, know how to read the results of the litmus strips when i test the water. It works..the colors change, but in my opinion, its not clear as to which color is which. I cant tell if its low or high or in the middle. Some of the colors look like they can be a few different ones. Any advice for this? Is there some type of "digital" tester I could use? This is the same problem many of us have. I use a Taylor drop test kit. I use a K-2005 but most recommend the K-2006 as it is more accurate. Quote Link to comment Share on other sites More sharing options...
Huskytub Posted February 6, 2009 Report Share Posted February 6, 2009 I do not, for the life of me, know how to read the results of the litmus strips when i test the water. It works..the colors change, but in my opinion, its not clear as to which color is which. I cant tell if its low or high or in the middle. Some of the colors look like they can be a few different ones. Any advice for this? Is there some type of "digital" tester I could use? Here's what I use: http://www.aquachek.com/PublicPopups.asp?a...duct&PID=24 Quote Link to comment Share on other sites More sharing options...
Whoneedsavacation Posted February 10, 2009 Report Share Posted February 10, 2009 I have had a much better time with the Leisure Time brand strips (for bromine) than other brands I have tried. Color changes are much clearer. Of course if you are color blind to any extent it could be problematic! They do make digital strip readers. Quote Link to comment Share on other sites More sharing options...
chem geek Posted February 10, 2009 Report Share Posted February 10, 2009 Of course if you are color blind to any extent it could be problematic! They do make digital strip readers. If you use the Taylor K-2006 for chlorine (or the K-2106 for bromine), you simply count the drops until the sample turns clear. You can see a demo of it here. You can get the Taylor K-2006 for a good online price here or you can get the TF100 test kit from tftestkits.com here with the latter kit having 36% more volume of reagents so is slightly better priced "per test". If you already have the other tests you need and just need a chlorine test, that is also available here. Richard Quote Link to comment Share on other sites More sharing options...
