I have a caldera alpine spa, sometimes the bubbles dont come out of the jets evenly or as strong. Is there something I have to clean or change and are there any upgrades I can do to this spa?
Check your filter or, call your service department. You can't fix it over the internet.
I understand what your saying ,but if there was something to look for that is common like cloged tubes or etc. What makes the bubbles in the system ,is that a part that goes bad ?
You may want to try some Swirl Away in the tub, (watch out for the foam), then drain and refill. This will help clean out build up in the jets that may be causing the venturi to fail. You may want to wait untill you were were going to drain the spa anyway so there is no wasted water. Then if that doesn't work, have a service tech. come and check out the system for you.
I would start with the filter.
How old is it, and how do you clean it?
B)
