Guest Ryan Moore Posted September 22, 2005 Report Share Posted September 22, 2005 I am looking into a new spa and have compiled alot of questions about the different brands. I am here in Sacramento California and very rarely does it get below 30 -40 degrees. I am curious, full foam or partial foam? Also, the brands I have seen that I like are, Master, Coast, Cal Spas, Elite. Are any of these good? I like the idea of a steel frame. I have looked at D-1 and Sundance but to be hones dont like any of their layouts. I was considering buying one of these at the fair but decided that the showroom may be a better route. Approx, how much should it cost to get the wiring done with the GFCI box? (running approx 50-60 ft from the electrical box) Standard new home with small backyard. Well, I guess thats all for right now. Quote Link to comment Share on other sites More sharing options...
Guest hottub.pool_boy Posted September 22, 2005 Report Share Posted September 22, 2005 In connecticut it runs about $400-$600. or go to your local building dept., if you're handy, take out a permit and the building official will give you the guidance you need to do it yourself. Think about a HotSpring or TigerRiver. Quote Link to comment Share on other sites More sharing options...
Guest Rick Posted September 22, 2005 Report Share Posted September 22, 2005 Master Spas is a good line. I dont know much about Cal or Coast, but havent seen very good info on them on the various spa sites. I would call around on the electrical. Prices will really vary. If you can do a lot of the work yourself, it would be a savings, and just have the electrician make the connections. Quote Link to comment Share on other sites More sharing options...
treelady Posted November 2, 2005 Report Share Posted November 2, 2005 Our electrician's bill was around $900. Quote Link to comment Share on other sites More sharing options...
Chas Posted November 2, 2005 Report Share Posted November 2, 2005 Our electrical installs - 220v/50a with sub panel - run from $300 for right next to the main electrical panel, to $1700 to upgrade to a 200 amp main house panel and connect to the tub with subpanel. Quote Link to comment Share on other sites More sharing options...
stl-rex Posted November 3, 2005 Report Share Posted November 3, 2005 If you're open to suggestions, perhaps you might like one of Arctic's designs. They have a dealer in Sacramento. Galleria Billiards and Spas is the place. For Arctic, frame is irrelevant as the shell will fully support the water without a frame. But as a side note, spas have been successfully manufactured with both wood and metal frames so regardless of the brand, I would put that far down on your list. I would focus on trying to wet test a few and let that be your guide. By wet testing several brands/models, you will find a spa in which you fit well and whose jets feel "right" to you. If you are considering a lounge, a wet test becomes more important and these often fit a narrow range of people or the design causes excessive floating. If you are wondering, I own the Tundra. Quote Link to comment Share on other sites More sharing options...
