Guest Trevor Posted September 23, 2005 Report Share Posted September 23, 2005 Hi - I have a ~450 gallon spa that constantly needs PH up/Alk Up and hardness increasing. Although the hardness seems to stay for a bit, the PH and Alk plummet almost immediately after testing. Meaning it only lasts a day or so before it's back down to below 'acceptable'. I use just chlorine for clarity and cleansing and shock treatments. How can I bring it up and *stay up? Or, why is it seemingly evaporating? Quote Link to comment Share on other sites More sharing options...
Guest james Posted September 23, 2005 Report Share Posted September 23, 2005 You need CYA--cyuranic acid, called stabilizer/conditioner under HTH label at walmart or Home depot. You can get it at pool stores too. Just put a small amount in a sock and let it dissolve in spa. It will help stabilize chlorine and keep pH level. Quote Link to comment Share on other sites More sharing options...
