Sta-rite Service System Light On
streeterhome
Is this a max-e-therm heater? If so, the service light means that it either failed to light, or had a problem with one of the sensors. Cycle power to the heater (turn off the breaker and back on) and try to use it.. What does it do? Ever hear it light, or a click that sounds like it will?
If you are comfortable working on your heater yourself, you can look at the control board on the top (underside of the display) and see if any LED's are on. This may tell us what error it is detecting.
  • 13 years later...
