streeterhome Posted September 3, 2008 Report Share Posted September 3, 2008 My Sta-rite heater was working the few times we turned it on earlier this year, now the service system light in on and nothing is happening. please help! Quote Link to comment Share on other sites More sharing options...
Discountpoolspa Posted September 5, 2008 Report Share Posted September 5, 2008 Is this a max-e-therm heater? If so, the service light means that it either failed to light, or had a problem with one of the sensors. Cycle power to the heater (turn off the breaker and back on) and try to use it.. What does it do? Ever hear it light, or a click that sounds like it will? If you are comfortable working on your heater yourself, you can look at the control board on the top (underside of the display) and see if any LED's are on. This may tell us what error it is detecting. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted September 12, 2008 Report Share Posted September 12, 2008 "now the service system light in on and nothing is happening. please help!" If the "service system light" and not the "service heater" is lit, Your problem is something other than the heater. Quote Link to comment Share on other sites More sharing options...
gregmikol Posted June 12, 2022 Report Share Posted June 12, 2022 Service System light comes as soon as I turn pool ON. The PS LED is on at the same time. Jumpered water pressure switch - still the same Quote Link to comment Share on other sites More sharing options...
