Guest Curt B Posted September 23, 2005 Report Share Posted September 23, 2005 I'm hoping someone can help me.I've got a morgan newport spa.I've replaced the pressure switch and adj. Heater will shut down but pump continues to run even thought its at temp.I'm able to shut down motor manually by breaking contact at solenoid,contacts are ok.Thanks for any help! Quote Link to comment Share on other sites More sharing options...
Chas Posted September 24, 2005 Report Share Posted September 24, 2005 --> QUOTE(Curt B @ Sep 23 2005, 03:35 AM) 515[/snapback] I'm hoping someone can help me.I've got a morgan newport spa.I've replaced the pressure switch and adj. Heater will shut down but pump continues to run even thought its at temp.I'm able to shut down motor manually by breaking contact at solenoid,contacts are ok.Thanks for any help! Is it simply a time delay? Many tubs will run the pump for a short time after the heater cuts off to carry any leftover heat into the tub and cool the heater down. Check the owners manual to see if your spa has this feature. Quote Link to comment Share on other sites More sharing options...
