proxy Posted April 27, 2008 Report Share Posted April 27, 2008 Does anyone know of scuba gear that I would use in order to get a drain cover replaced? Basically, I do not want to drain the pool to fix this. I know there are guys that specialize in this type of thing and they go under water using some kind of breathing device. Anyone know what device they use? Thanks a million Quote Link to comment Share on other sites More sharing options...
ParagonPool&Supply Posted April 28, 2008 Report Share Posted April 28, 2008 ive replaced drain covers in 10 feet of water using my lungs...whats so complicated about this repair?? Quote Link to comment Share on other sites More sharing options...
zman Posted April 28, 2008 Report Share Posted April 28, 2008 ive replaced drain covers in 10 feet of water using my lungs...whats so complicated about this repair?? yea..Me too. What is so complicatede is what kind of cover it is. There are the kind that turn and lock or the kind that have screws attached. The device you can use is an oiless compressor, or a hooka. if your just a homeowner and want to save money then dive for it. If you can prepare yourself for the job without getting wet then thats good. Look at the cover. do you see shiny metal screws? If not then you might have a 1/4 turn grate. American products uses the screws usually but here is the problem. The screws get calcified and can become unmovable. You do not have to drain it but you do have to know the cover your trying to remove. Quote Link to comment Share on other sites More sharing options...
