miandsh2000 Posted June 12, 2006 Report Share Posted June 12, 2006 has anyone - or know if we can - installed a fiberglass pool above ground? its a 16x40 V bottom pool (goes from 3.5' on the ends to about 6' in the middle) and i want to install the center V section about 2 feet in the ground. this would give me about 4 feet above ground in the middle. can this be done? Quote Link to comment Share on other sites More sharing options...
midwestpoolsmichigan Posted June 13, 2006 Report Share Posted June 13, 2006 Viking Fiberglass Pools are allowed to be installed as much as 18" out of the ground. Quote Link to comment Share on other sites More sharing options...
Steamboat Posted July 4, 2006 Report Share Posted July 4, 2006 has anyone - or know if we can - installed a fiberglass pool above ground? its a 16x40 V bottom pool (goes from 3.5' on the ends to about 6' in the middle) and i want to install the center V section about 2 feet in the ground. this would give me about 4 feet above ground in the middle. can this be done? Ask the vendor if their product can be installed above ground and request complete installation instructions (make sure this doesn't void their warranty). You will most likely have to build a wood deck around the pool with substantial bracing for the side walls of the pool. Our Alaglass pool is installed partially above ground (4 feet out of the ground at the deep end) but getting correct installation guidelines from the factory was extremely difficult until we asked the right person then it was a simple fax of 2 pages. We braced the pool with much more substantial bracing than called for by their instructions ( we felt their instructions weren't adequate and didn't match their current pool construction). Quote Link to comment Share on other sites More sharing options...
