Showing results for tags 'vita spa'.
I have a Vita Spa 700 series Chateau, model DC780 and I'm looking for a schematic and repair manual/guide. I'm having a problem with both jet pumps not coming on, but the air pump, heater, and circulation pump work just fine. I'm thinking this is a board issue, I check for voltage at the pumps, and not getting any. I would like a schematic to make sure I'm checking for voltage correctly. What else could cause both pumps not to come on? Thanks for your help!
Hey guys, I finally got my Vita Spa Vintage LH hooked up and filled up but have a few problems. First no heat, no heat indicator lights and the high limit switch isnt tripped (checked to see if the lil red button had popped) Secondly, when i flipped the breaker the bubbler kicked in automatically, but the pump for the jets wasnt running. It only runs when I hit the Jet button on the control panel, and the jets arent working. Tried the 3 valves but no luck. My control panel has the old style temp dial with a button for jets,blower,and light. They all have indicator lights at the top. Any ideas?
