Showing results for tags 'troubleshooting done'.
Found 2 results
  1. Details: 2001 Cal Spa Genesis 110v Last week I installed a new 1.5 hp hydromaster motor/pump with new unions, new flow switch, new Clear Blue Ionizer and a new filter When I first turned it on, it heated to 104. The next day I went out and it was 100 and the heater light wasn't on but the water was circulating as if it were heating. I got in and ran the pump on hi and adjusted the temp. When I turned the jets off the heater turned on, but the next morning it was off again. I unplugged it and it didn't heat when restarted. Pump is running, as it would when it is heating. I clean
  2. My Sundance Altamar 850 recently stopped working unexpectedly. Power comes on for a second then goes blank. Originally thought it was the LCD panel but trouble shooting found that when I unplugged the sensors plug it stayed on. Tested all 3 (temp/ hi-limit/flow switches) and they all has power. None of the fuses were blown either? Any thoughts?
