Showing results for tags 'temp control'.
I have a second hand hot tub that I received as a gift and we got it running a couple months ago. We have had some issues lately. It was running fine for about a month until the control panel began showing only a blinking “ready” and blinking “power.” The jets and light work fine but the temperature began to drop and after some research I assumed it must be the temp sensor. My boyfriend replaced that for me yesterday and at the time the water was warm, but not hot. After 24 hours it is starting to drop in temperature and isn’t nearly as warm. Now the screen is just blinking “ready.” I tried turning the power off at the breaker and turning it back on and it starts up fine and screen looks normal but then after about 10 seconds something clicks and the screen just goes back to blinking “ready.” It’s in the 30’s here in NH and expecting snow soon, so hoping to fix it before conditions get worse! But not sure what else it could be! Water level is over the jets... is there something else we can do? Maybe an issue with the part replacement? Thanks in advance for any advice or help!!
- temperature problems
- hot spring
- (and 10 more)
Hi...I have a 5 year old Soft Tub 300. It has worked well till now. The temp control would only go down and not up past 100 deg. Now it won't go down or up just stays at 100 deg. I've removed the top of the control unit but it is encased in expoxy? Any suggestions? Thank you, Paul
Hello all, My 97' sundance cameo 850 won't let me change the set temp when powered on. It's stuck at the factory 80deg F The up and down arrows work on the pad, the two temp probes show a very similar reading for the correct number of ohms. The screen won't lock, but does let you change the time using thoes keys. Any ideas? Thanks!
