Showing results for tags 'spa heater'.
Hello everyone. I have been using an mspa silver cloud inflatable spa for a while and I like the heater/pump but the plastic tub is very hard to keep clean. I had the idea to buy a cold water wooden tub and use the mspa heater to heat and pump the water. It would be quite easy to plumb in but I can't seem to match up the threads of the inlet and outlet? I have attached pictures and dimensions. Does anyone know what they are? Thanks in advance.
- spa heater
- inflatable
Hello, I am hoping someone can help me with this problem, My spa will not heat anymore past 86 degrees unless its hot outside. everytime I run the spa heater it also turns on the pool filter pump and the jacuzzi water spills into the pool. It used to be able to run the spa heater alone and the pool heater alone but now its stuck doing both at the same time. everytime I try to turn off the filter pump while running the spa heater, I get this message: "pump will remain on while spa is on" then if I shut off the spa heater it shuts off the filter pump after a cool down?? I am new to this so I am not sure how to navigate the controls. I have a Jandy Aqualink RS12 system and If anyone can help me figure this out, I would be grateful. Thanks so much and please let me know if you need more information. Bobby
I have a Hayward H350FDP propane heater for my spa that is about 7 years old. It turned the unit on this weekend which is run at least a couple times a month and I could hear the blowing blowing but the heat and gas would not kick on. What kind of things can I trouble shoot to see what the problem might be? The only error code on the screen was b0 which I think it just something to do with a bypass to use the remote. Thanks
Help with the understanding of how they work. I was given a 1997 DYNASTY DYN2000Hot tub. Was told it was working before disconnected. As far as I can tell everything except the heat is working. I ohmed the heater out and it was 12 ohm. I understand that is good for this heater. I just am not getting voltage to it. Where to start. No errors on the control pad. I understand overheat freeze protection pressure all play a part. But there are no errors to indicate any issues there. where next. Thanks
- 2 replies
- spa heater
- understanding controls
Just bought a used Jandy lite 2 250LJ pool heater. hooked this thing up and it ran for 5 to 10 min. then it quit and the control display flashes on and off no codes just everything flashes any help would be very appreciated.
- pool heater
- jandy
