Showing results for tags 'solar'.
Hi bought a house very cheap because solar that heated pool on roof leaked causing a hole in roof. Now solar was removed and pool plumbing (Solar)capped off. So when I turn on my pump it works fine however when I go to hook up pool sweep in skimmer it does not move it’s almost as if the pump stops working also. I’ve checked for leaks on hose on lid at unions I’ve used a drain bladder at pump and skimmer. However there is a Jandy valve that is labeled solar on one side and pool the other when I turn valve to pool I hear a rush of water in pipes at pump I’m not used to hearing however it actuall
It's finally time for me to update my inground pool. At 17 years of age, the liner was still the original (RIP - literally). I wanted to fill the thing in, but my wife feels it could be a thing of beauty once again. I lost the battle. My conditions for keeping the pool included spending money on a robotic bottom/side cleaner, and a robotic solar surface skimmer. I also got a Pentair SuperFlow VS pump and a Hayward saltwater chlorinator. Keeping my Sta-rite filter and heater. I know I won't be maintenance free - but as close as you can get in Pennsylvania with lots of trees and shrubs ar
Where is a good place to buy a cheap solar pool heating system? I'm in Sydney, NSW but I don't mind ordering from the net if the cost is right. I have had some expensive quotes from some of the local stores, I'm just questioning if there are good deals out there. Even I am looking for such supplier/ manufacturer who take personal interest on my requirement and give me the best option to buy solar pool heater. The pool I'm looking at will be approx 10m x 20m with a structured deep end.
- 6 replies
- solar pool heater
- Solar
i have a new 12ft diameter outdoor pool, just bought a solar cover for it. However, I'd like to use a chlorinator as i've been told they're good at keeping the levels just right. can a chlorinator be anchored down in the middle of the pool (a bit like a bouy) so it doesn't touch the solar cover. If the filter is on and the water is moving, then i can't see the problem.
- chlorinator
- pool
