Showing results for tags 'slow heat'.
Found 2 results
  1. I have a sweet water spa and filled it two days ago after being closed up for the winter. The temperature has only climbed to 69 degrees as of this morning. I have changed out the heater element in the past due to no heat , this is a slow temperature rise so I am not sure if it a problem with the element or something else. Can anyone help?
  2. I am chasing an issue with my 2003 Hot Springs Grandee. The hot tub is only heating to 90-94 and will occassionally reach 98. Symptoms: Heat will only increase with Jets on 94 degrees avg temp when thermostat set at 100 Took 3 days to come up to 90 degrees after refill all pumps and Ozone seem to be fine and running with no issue Running without fitlers installed- same result- low heat Bubbles are coming from bottom drain when main pumps off When I lower/raise thermostat I can hear and see heater LED come on and off I have turned off both mains 20 and 30 AMP to reset plus main on fuse box for 30 mins Remediation steps to date: cleaned all filters in proper way Replaced both thermistors first- no change Replaced heater - no change Any ideas are appreciated. Thanks in advance. Sole
