Showing results for tags 'salt water pool'.
Found 3 results
  1. Hey Guys I just got a new pool put in my yard. 38K gallons salt water. Has ozonator. I've gotten 3 water tests in the last 3 weeks and the first one told me to add 18 pounds of bioguard stabilizer 100 (cyanuric acid). Literally spent HOURS pushing it around my pool until it dissolved. Then most recent test a little over 2 weeks later said my cyanuric acid levels were back down to 0 and that I needed to add another 18 pounds. Is that even possible? If the sun is out, it is on my pool all day. Never gets any shade. But I've read and seen in so many places that you only need to treat your pool with cyanuric acid once per season. Why have I had to put 36 pounds of it into my pool in less than 3 weeks? If anyone has any suggestions or ideas, I would greatly appreciate the feedback. Also if there is another way I can maintain the cyanuric acid levels without having to spend 10+ hours doing so, would welcome those suggestions too. Thanks, Jason
  2. opened pool, shocked and after about a week water test everything within range except Chlorine was a little high at 4. CYA 90, PH at 80-90 Calcium at 230 was within range. Total Alkalinity cannot be detected as instead of becoming pink [using taylor] it became slightly orange. What is going on? Pool meter show salt at 3200. What can I do? Thanks
  3. Hello, Which brand has the most reliable products of Hayward, Jandy and Pentair? It's for a salt water automation/clarification unit. Thanks!
