Showing results for tags 'replace'.
Hi, I was removing the jets from Dr Wellness G2 Tranquility series. To clean them. One of the smaller jets snapped. So I have the round silver and black top of the jet, but the rest of the jet is STUCK. I've tried everything I can think of to get it out. Are there special tools? Any suggestions for how to get it out? Or, is my only option to open up the hot tub, cut out the insulation, and remove and replace entire jet housing? Thank you Michele Also trying to find out part numbers for Dr Wellness g2 tranquility spa jets so I can order replacements. Called LPI and they were not helpful. Called Aqua Living store and they were not helpful either. Anyone know what I can use to replace my existing jets? Thanks.
- 12 replies
- replace
- dr. wellness
- (and 5 more)
Dr Wellness Spa G2 Tranquility. Hi, I need to replace this insert or even replace the entire jet assembly body thing. Can anyone help identify this by part number, or point me to a replacement product. I believe this is called a "directional" jet. Thank you in advance. Michele
Replacing the Jet Pump motor on my 2004 Caldera Spa, and cannot get the pump section off of the motor. There doesn't seem to be any bolts/screw/nuts I can loosen to remove it.
