Showing results for tags 'pvc'.
I have developed a leak in my Hotspot TX triangle spa. I noticed the water levels dropping dramatically. So I went to investigate and found water dripping from the bottom of the spa skirting. So using that drip as a locator I removed the glued on skirting and the insulation inside to find wet insulation and staining from water. I removed all the insulation and noticed a fracture or crack and water stains in what looks to be a union or splice piece of PVC right before the tubing makes the turn to the foot massager jet. (Photos attached) I am looking for recommendations on a durable repair/replace method. I didn't know if you could just silicone the crack or maybe use some amalgamating wrap or waterproof tape or if it needs to be replaced completely? If replacement is necessary how would be the best way to go about that? Thanks for any help.
I have a very old (20+) years Garden Leisure spa. It's circular and only seats four people at the most. I recently replaced the GFCI plug receptacle successfully, but upon filing, there is a small leak from the pipe connection just before the valve. The water drips off the bottom of the valve, but is in fact coming from the pipe connection to it. See photos. I'm not sure what valve this is, as we no longer have the manual and information online is impossible to find, but it appears to be a gate valve. There's only one pump. Is there an easy way to patch this leak without replacing the valve? If I do have to replace the valve, can it be replaced with only PVC pipe and forget about the valve? Thanks for your help. IMG_1037.HEIC IMG_1041.HEIC IMG_1042.HEIC
My outdoor spa/hot tub started leaking two winters ago so I took it out-of-service, and had the local dealer out to look at it this Spring. They charged me $120 for a visit, spotted an obvious leak, then told me they no longer service spas. 8^( The good news is that apart from the obvious leak, and a few top-side parts that should be replaced (easy fixes), the controls, heater and pumps all seemed to work properly. Not bad for a tub that’s got to be 12-15 years old. So I gave up on it and tried to give it away this summer. No luck. Two potential takers both backed out after realizing what it takes to move one of these. Now I’ve got it blocked up, cleaned up a bit, and am determined to at least take a shot at repairing the leak. I got under the tub tonight and found the obvious problem… and I’m not happy. There is a PVC cap at the end of a manifold fitting and the cap hangs lower than any drain on the unit. Duh, I wonder why it cracked? Really poor design IMO. I was prepared to replace or patch a section of pipe, but this thing has me scratching my head. Not sure if these photos will help, but I think you can clearly see the crack looking from below in the first photo…I didn’t even have to scrape away any insulation. The problem here is that in order to try and get the cap as high as possible, the manufacturer jammed it on tight against the manifold stubs, one of which is not even used. Got any advice for repairing or replacing that cap? If I cut it off there’s no manifold left to slip a replacement cap on. So my thinking is to either: A) clean the surface of the cap and place and glue a new, larger diameter cap (if there is such a thing) over it, or drill a hole in the end of the cap and/or force the crack to open up so I can (hopefully) remove the entire cap. If I can do that, do I have any hope of cleaning up the old joint so that I might be able to install and seal a new cap? Thanks for any wisdom you can share.
Hello Everyone. Reaching out here, in the hope of some of your wisdom and help pls. Guess what i did ? Yup. chlorine capsule escaped to the bottom of the above ground (bestway) pool. i didn't see it until the following morning. By then, the chlorine had burnt through (dissolved) top layer of the pvc liner. through to the mesh layer. i did panic, but actually it didn't see to be leaking much water since water pressure seemed to seal the other pvc layer, to the floor (ground). the affected area is about the size of my hand. i tried putting on those pvc repair patches. but they float off within an hour. water pressure when the pool is full seems to prevent much water leaking. but i really want to patch / cover up the area where the pvc top layer has dissolved. or to buy a large (1 foot square patch) and attach that. does anyone have any tips or suggestions ? ideally if i could just get a strong glue / adhesive to cover the abraissed area (when the pool is empty) then maybe ? i thought of even a strong silicon that you put around the bathrooms seals? but kids jump in the pool and so there feet i would assume would wear away the silicon. is there like a paint glue i cant jut put over the affected area, to give it a rubber seal ? (i'm intending on lifting up the pool, and putting another layer of plastic sheeting underneath so that water pressure again forces the pool liner into direct contact with a plastic flooring, prior to the ground. very much appreciate any thoughts. (i'm in south italy, and so dint have the abundance of DIY stores i'm sure you luck people have elsewhere) jez
- 2 replies
- above ground
- pvc
- (and 6 more)
Hi, bought a home that came with a 1999 Coleman Spa. The previous owner did not drain it and a 1 1/2" PVC pipe froze up and broke along about a 6 foot run. No big deal. BUT along that run is five 1 1/2" T fittings that tie into flexible PVC tubing. And a female 3/4 inch is too small and a 1" female PVC is too big???!!! I figured spas had their own format, So I ordered 1 1/2 T's with a 1" opening for the lines. They are too big. The lines seems to match the outside diameter of a standard 3/4" PVC fitting. But no female openings are designed for external diameter fittings; only internal. So how what "T" do I use and where do I get it? The local MAxx/Coleman dealer had the 3/4" but they do not work.
