Showing results for tags 'pump 1'.
Hello everyone, I've had my 2012 hut tub since new and have had no issues with it... until this winter season. When the outside temperature reaches approximately -4F (-20C) or below, two things happen: Pump 2 engages and doesn't shut off. I have to manually turn it off. However, when I manually turn it off, it will turn back on when a) a set filtration cycle starts, or a call for heat occurs. The heater is not turning off when the desired inside temperature has been reached. For example, I keep my hot tub set at 101F, during a cold two week stretch we had the tub reach 114F because I left it for a couple days and didn’t manually turn off. If it's anywhere above approximately -4F (-20C), the hot tub operates as expected. Calls for heat at the right times, goes through the filtration cycles correctly, etc. I tried changing the filtration cycles to see if that does anything... which it didn't. I've reset the system, still didn't do anything. So I guess what I'm looking for is some suggestions on how to troubleshoot this. Don't know if it's a board issue, pressure switch, heater, etc. I've tried Googling this issue and I haven't found anything similar. Outside of moving to a warmer climate, please help! Here's some additional info: 2012 Sundance 680 Series Two pumps - Pump 1 and Pump 2 (no circulation pump) Here is an excerpt from the manual that may be of interest: Approximately two minutes after power is applied to the spa, the first filtration/heating cycle turns on pump 1. With two pump models, an automatic five minute “blow-out” function also activates pump 2 for a period of five minutes to flush all lines. Then, after five minutes, pump 2 turns off and pump 1 continues to operate for the duration of the cycle. Thank you.
