Showing results for tags 'leak valve sundance'.
Found 1 result
  1. I checked my spa last night only to discover that it was about 1/3 empty. It is a 2007 Sundance Majesta. Upon removing the right front panel, I discovered that when power was turned on to the unit - but no pumps were turned on - water was pouring out of what looks like some sort of relief valve hose on the upper right side. The hose continues down to the top of the drain valve on the bottom left. I suspect this means there is a problem somewhere else, causing this pressure valve to leak. Any ideas, please? Thanks.
