Showing results for tags 'jets pump'.
Hello I have a hot spot xs 120V that is just over 2 years old. Last night, 4 dashes appeared and my tub stopped circulating and heating but the control unit operated and the lights worked. I was in the tub with the jets on low and suddenly they stopped and 4 double dashes appeared on the control unit. Also my motor has started making a squealing sound periodically. I’ve had my pressure switch replaced as of November 2021 and the problem went away for a couple of months. Now this issue is back + a periodic motor squeal. When I reset it will run fine for a while (can’t time it) then back to four dashes. I’ve already drained and refilled the spa and my filter is clean. Attached is a video of the motor squeak. Any advice is welcome IMG_3028.MOV
I noticed that my water temp was at 109, pump and jets are running constantly. Regardless of setting, standard, economy or slow. I have checked that it is not in constant circulation mode. Tried resetting but no joy. No error codes on the display.I can turn on and off the high speed jets, lights work ok. I am thinking a temperature sensor has gone, but not sure where to start, any help greatly appreciated.
