Showing results for tags 'jets not working'.
I've obtained (free) a 2002 Tiger River Bengal, 115 v Spa. 1st problem is jets only pulse when “Jets” button is pushed. Previous owner thought heater wasn’t working either. The LIM LED (green) is on. Heater has been set down to 80 so it doesn’t come on. When the heat is turned up after ~a minute SPA shuts off. When “Jets” button is pushed LED D18 flashes and the motor tries to get the jets going. You can hear the relays switching. I’ve bled air from lines, can hear motor running, can see shaft turning, can't tell if impeller is turning. The “comfort control system,” smart jet lever is turned to 3 o’clock. Water pulses out of “comfort control system” area. I’ve tried turning lever to other locations, it turns easily, though not sure it is actually moving. The Spa had been empty and unplugged for a couple years. Pretty sure I’ve got, at least 2 issues to resolve, Jets & heater.
- Tiger River
- Bengal
Hi, Our tub has two pumps, both are working, but some of the jets are not functionning. Pump 1 is working fine. Pump 2, which includes the volcano floor jet is not working properly. It should have two speeds, but only works on full throttle and more - we have a fountain in our hot tub! Not all jets have water/air coming out of them. We have turned the valve that switches the jets to the volcano pump and no change. We regularly empty and refill out tub and always drain the air out of the valves. Thanks.
