Showing results for tags 'issue'.
My HydroSpa Mark 3 is showing an ice error message on the screen, but remains functional. It’s sometimes sends the jets and bubbles on, repeatedly, always showing the same message but also sometimes runs perfectly fine. I don’t know what the problem could be… Could anybody help? Thank you.
Hello - I have a 450gal tub that is 2 months old and I have a constant recurring issue. I filled the tub, added sodium bromide and shocked with MPS...I also have a bromine floater that is in the tub that I have set to "all the way open". I find it impossible to maintain a bromine readout from day to day. If I add dichlor I get a nice readout, but within 18 hours the readout goes to 0. Last night, I shocked w/MPS to try and reactivate the bromine. I will run a test strip tonight to see if there is anything, but the only thing I noticed this morning is that it made my water cloudy... Please help! UPDATE: Last night I was actually able to get a readout of bromine in my spa, which means something is finally working. The next question I have would be how do I maintain this level of bromine? Just keep shocking with MPS weekly, or is something else required more than that?
posted on the wrong forum - please delete.
I used the hot tub (built in, overflow fountain into pool and little fountain in the middle of hot tub) for the first time, and it took a lot of guessing to figure out how to turn jets on/fountain off, etc. Finally got that figured out but now that I am trying to return it to normal I'm having trouble. I'm not sure if all the valves are turned right, but I figured out how to get all things solved... fountain at right height, small fountain in pool on, and jets off, but when I turn the valve that way the hot tub drains really quickly. Tried turning different valves different ways to see if drain was open when that valve turned, but no matter what I tried it's still draining. When I turn it back to how it was before draining, the fountain in hot tub is at the right height, but the jets are still on and the pool fountain is off. I don't know the names of certain pipes or any of that, so what I have googled hasn't been much help, or I thought it helped but hot tub still is draining. Could get pictures if needed. Help!
