Showing results for tags 'help'.
I'm a new hot tub user and for about a week now I've been having an issue of just above 0ppm bromine levels, my pH and TA are completely fine and in the correct range although the bromine is next to nothing, I have a Sundance Optima 880 and I tried using the Brominator and a floating dispenser both together and one at a time and neither has fixed my issue and now just yesterday when the jets are on the hot tub starts to create foam. During the refilling stage I used infused bromine granules as I heard this is something you're supposed to use to boost the bromine upon refill, this worked a
Howdy! first time on this forum, hope everyone is having a good day. I'm trying to replace the circulation pump in a Balboa EL Neptune (pretty sure that's what its called) Original pump in Hot tub was a Waterway cp-1/15-1n22a 3410020-0E motor The pump motor specs are labeled as follows 1/8 H.P. 230v 0.8A S.F. 1 1725 RPM Continuous run time. Just about every reasonably priced pump ive found (sub $200) is rated at 1/15 H.P. Does it matter? Should I spend ~$300 to get one rated 1/8HP even if the lower HP motor has the same RPM? also the one i keep seeing (Iron Might 341
I have a spa that overflows into my pool. I noticed the jets suddenly were not pushing out much water, then my blower was not working. I replaced the blower, the new blower kept overheating. We narrowed it down to having some sort of blockage. We had rotorooter try and clear the line (way overpriced) then we used a gas pump and pulled the water back from the spa, hoping to dislodge anything, there was a small piece of plastic that came out. Then we pumped through the jets in hopes to push anything out. STILL, the blower is overheating and the jets seem very weak without the blower.
- spa
- troubleshoot
I took the filter of my lazy spa pump when it was raining and now its leaking from the bottom of the pump. what have I done to it can you help please. 😔
I replaced the heater element in a maax spa and everything was working. I decided to test the element with a multimeter and did it wrong. There was a big boom and the spa turned off. Now it won't turn back on. Is the board fried? Should I try and replace the definite.contactor? Any help would be appreciated. When I flip the breaker nothing happens.
Hi Everyone, looking for some help. My hot tub display dropped to 60. When I unplug it and plug it back in it starts at 100 and slowly works it way back down to 60. When I try to press the buttons up the temp just falls back down to 60. It still feels pretty warm in the tub but not 104 that’s for sure. I’m worried because it’s so cold here right now and won’t warm up for months, it’s -4 f here right now. I think it could be the topside display? Any thoughts? Additional information it’s a 2007 x400 dream maker spa. Thank you so much Erika
- dream maker spa
- topside
Hi all, We recently got a 2004 Caldera Spas Utopia Geneva from some friends, built a deck and had it wired up but I'm having a problem. After turning both the 30 and 20 amp breaker on, the spa starts up. The 'LIM OK' light comes on and the 'HTR OK' as well. The circulation pump starts working and after 5 minutes it goes into the auto clean routine. The air blower starts and runs for a minute but when Jet 2 turns on low it trips the 30 amp breaker after a second or so. If I manually start Jet 1 or 2 it trips near immediately. I released the union on top of both pumps and only found one to
We just got a used 2008 Dimension one California jasper model hot tub. We are new to hot tubs. We ordered new filters and installed them. The tub heats up but we keep getting “Low flow error”. Not sure what is causing this to happen. Just want to enjoy my new spa and we have yet to make it in. Thanks to anyone who can help.
Okay guys, I seek your expertise! I just bought this master spa 66t9 the other day. It has been sitting for over a year. Some of the jets seem clogged but all functional. I want it to be as close to perfect as possible. Under the control panel there is this hose that appears it broke off from somewhere but I cant seem to find where it is suppose to be hooked. It doesnt leak water or anything since it is the same hose that is wrapped up and ziptied, and covered in the foam in the left side of the picture! Any ideas to where this tube should go or connect to? Please help me! lol. I'm a spa newb
My hot tub keep cutting off and displays the OH. The tub is about 15 years old. It is not even heating up to the temp setting of 103. It will run a couple of hours then shut down with the OH on the display. When the temp gets close to 100 it shuts down. I have checked the filter and cleaned it. I have opened all the valves, the pumps are working as it should. I replaced the heating element with a heavy duty one about 4 years ago. I have cut the breaker off several times to see if it would reset itself. The temp was 98 and it cut off with the OH on the display and will not to anything even whe
Hello - I have a 450gal tub that is 2 months old and I have a constant recurring issue. I filled the tub, added sodium bromide and shocked with MPS...I also have a bromine floater that is in the tub that I have set to "all the way open". I find it impossible to maintain a bromine readout from day to day. If I add dichlor I get a nice readout, but within 18 hours the readout goes to 0. Last night, I shocked w/MPS to try and reactivate the bromine. I will run a test strip tonight to see if there is anything, but the only thing I noticed this morning is that it made my water cloudy... Please
posted on the wrong forum - please delete.
Spa is not heating, voltage to each element is 120v. But when I set the temp up to 104 the spa kicks on for a shot while and then shuts off. I don't hear a low speed pump circulating. What way should I go, change the 2 speed pump or replace heater?
Hi Everyone, I've been referencing these forums for a while now to help maintain and troubleshoot issues with my spa and now am hoping that someone may be able to help me figure out what is going on with my G3 tub. So, after having my tub shut down for about a year now I've been trying to get it up and running again. After flushing the tub, cleaning it and refilling it I was getting a DR error code. At first, foolishly, I thought it might be the heating element being burned out as it was getting old but even after replacing it still was giving me that low flow error message. After replacing
Hi! Im new to this forum, I just acquired a older model Jacuzzi hot tub. The model is 8780000 ( Caressa). Got a pretty good deal on it since it doesnt leak, and all the side wood is in great condition. Its wired for 115vac 20 amp. I ran a dedicated line (gfci of course) and bonded the tub to code. However when we plugged it in the first time we realized it wasnt heating after 24 hours it didnt warm up not even a degree. After looking up some information I realized it could be the heating element. Below is what I did to replace it Unplugged the tub drained the tub to below jet level loosene
- 10 replies
- heatjacuzzi
- element
(and 6 more)
Got it! Problem solved.
I purchased a used Leisure Bay hot tub (2001 Smart Series Model1900-s) and wired it up and noticed that the pressure switch assembly had rusted to where it was causing a leak, so I cut cut it off and ordered a new assembly. When it came in I installed it and turned it back on and hit the jets button and heard it attempt to run for a second then it died and would not cut back on. Further investigation let me to a blown 20 amp fuse, I bought some more and replaced the fuse and it came back on but I didn't press any buttons this time and just let it run and it ran for about 30 seconds and you c
- Leisure Bay
- Hot tub issues
I just bought an Artesian Island Series 6 person Lounger that's a few years old. I need to move it across town to my house. I have a trailer and plenty of help. What is the easiest way to move it? Can it be stood up and transported on its side without damage? It also has to move about 30' to get to the trailer. Is there an easy way or should we just try to muscle it? Thanks!
- 2 replies
- Move
- Transportation
- (and 5 more)
I went out this morning to empty the skimmer baskets and noticed my pool was not circulating and the jets had nothing coming out. Went over to the pump/filter system (Hayward) and it was not doing anything. Checked breakers and turned them on and off a couple of times. Took the top off the basket emptied what little was in it and closed it back. I tried backwashing as well and nothing. There was almost full water sitting in the basket compartment. I took the hose and water was draining from there so I know it's not stopped up. What could be the problem? Also everytime I vacuum and t
Hi everyone: We just moved a hot tub, ran new wires, filled it up and thought it was working fine, until it didn't heat up. I have been reading posts online about what to do and I am completely lost. One thread I read says to press the red reset button on the heater but I can't find one. Also, the electrician isn't completely sure if it's hooked up correctly because what is in the panel doesn't exactly match what's in the manual and the cover of the panel is a little confusing. All jets as well as the light work. There are also lights on the circuit board. The power light is green and t
- 2 replies
- Hot Springs
- Grandee
I have a Hot Springs Envoy spa that is about 7 years old. It has a minor leak. Due to the location of the tub on my deck and the remote location of my home, the labor repair cost alone will be about $4,000 (removal of the deck railing, crane, etc.). I had a technician come out and look they can only access the front panel where all of the pumps and control panel are located. They do not see a leak at the pumps. As a last resort, I am going to try a liquid stop leak in a bottle product. Has anybody had any experience (success?) with this type of repair? I have looked at several brands: F
- 4 replies
- hot springs
- spa
