Showing results for tags 'flex pipe'.
Bought a new filter and multiport valve. The valve connections are backwards from what I have so I need to plumb the pump to the left side (see picture) of the valve. Thinking about using flex PVC to make it gentle, it would otherwise require 4 90s at least. First, thoughts on this approach? While I am at it, I also want to put a check valve before the pump so that the pump doesn't always drain back to the pool and stress the pump on priming. Do I need a check valve like they have there at the inlet side to the multiport valve? Seems useless and I am going to redo right back to the pump and delete the cleaner line and associated crap you see to the right. I was thinking rigid pipe to a union to flex pvc from the pump. My return that runs through the heater would also be redone for better flow. Overall this seems like the best approach to me.but wanted to ask here if I have missed something? Questions. 1) thought on check valves, delete the one at the valve and add one before the pump? 2)flex PVC as opposed to some hard pipe gymnastics? I think the flow may well be improved and thus make the new pump more efficient. Thanks in advance.
Upon opening my pool this year, I was greeted with a leak. It took a while to locate and extract the damaged pipe. Turns out it was in a piece of Flex PVC pipe. I'm trying to determine the cause of the failure... 18 years of use before rupturing. The pipe was completely encased in gunite. Anybody seen bulging in a pipe like this? Any ideas?
Hi I have in-ground vinyl liner pool that is in the process of liner replacement , I decided to replace the skimmer , since it has been there for at least 20 years . So I broke the patio concrete , dug up the skimmer , and discovered that an opening in the steal wall where skimmer mounts to is corroded , especially the bottom portion , the clearance holes where screws goes through are rusted out to the point that i can't mount thew skimmer . My few questions are as follows : Can I cut new opening for a just a few inches over in the steal wall and drill new clearance holes ? Plug old one with a piece of sheet metal and move the skimmer over ??? Can I use a piece of flex pipe to connect the skimmer to an existing rigid pipe that is coming out of the ground ?? I would appreciate some input from you guys
- skimmer
- installation
