Showing results for tags 'flashing red light'.
I got a used hot springs prodigy H from someone. I finished hooking it up yesterday and filled it through the filter housing with a hose. It ran perfectly fine, heated, jets all ran fine. I put system flush in to clean out the jets since it had been sitting. I then drained the water out. When I refilled it, I thought it would be smart to siphon water through a hose from my pool so it would start out clean, I did put it into the filter housing, but slow flow with the siphon. When I powered up the spa again, you could hear the spa start up then it stopped and the control panel red light started flashing and nothing was operative anymore. I turned the power off overnight, took the gray standpipe out, put a hose down in the hole and covered with a rag around the hose, turned the hose on and it forced a big air bubble out the bottom return and I let that water run for about 30 seconds. Put pipe and filter back in and turned on power and it still blinks red, now it doesn't even sound like it tries anything, it will start blinking within 5-10 seconds. I don't think my heater has a reset button, I couldn't find it anyway. Any ideas?
- 40 replies
- error
- flashing red light
I'm looking for help with my 2002 Hot Springs Sovereign. The power light is flashing red. I know this has been discussed a few times here, but I was hoping to get more specifics. My circ pump was replaced by a tech about 1 1/2 years back. So, this is what I've done so far. 1- removed the filters and reset the breaker (a few times). Plus, tapped on the circ pump. 2- removed the circ pump, opened it to look for debris and visible damage. It was fine. 3- put a voltage meter on the circ pump cable, it was fine. When I turn on the power at the breaker, the spa tries to kick on. It makes a hiss and a clicking noise a few times and I can see water trying to flow out(?) of the heater(?), but its kind of just sloshing around. After anywhere from 20 to 60 seconds, it stops trying to come on and the light starts flashing. The temp is at 98. Should I snake out the line from the heater into the tub (something I've read in other posts). Or does any of this indicate that I do (or do not) need to replace the thermistors? Any help is appreciated, thank!
- 3 replies
- Hot springs
- circ pump
